Old 09-24-2011   #391
Default Re: LT5 Assembly Project
I then put the cranksahft sprocket on: Before you put the sprocket on the Oil Pump Seal Seat(pic below) must be put on:
Large shoulder goes towards the back....
The Crankshaft sprocket them must go on....its held in place 1)because the fit is tight as hll and 2) there is a wooddruff key.
May there is a trick to it, but I alligned the wooddruff slot in the sprocket by using the first wood slot in the crank, then backed the sprocket off, put the key out and placed it in the 2nd slot by the Oil Pump Seal Seat.
I then used tool J-38132 to drive the gear on (pictured)
I think heads and timing chain guides are next.
Old 09-24-2011   #392
In prep for putting the heads on, I had to replace the expansion plugs that were removed.
I went to Lee Auto Parts:
Stock size is 16MM
I used Dorman 555-108 which is .625 inches of 15.89mm
Stock size back of heads; 30.3MM I used Dorman 555-021
The Dorman is 1.199 inches or 30.45mm
Pete mentioned its a good idea to stake these are they tend to leak...staking is striking the opening to create a small lip from the aluminum that keeps the plug in place.
Old 09-25-2011   #393
Prior to putting the heads on and when assembling the pistons, be sure to check and make sure the rods are are facing the proper direction; the larger chamfer should be facing the bob wieght.
Another easy way to check is to look at the rod number position....with the engine upside down on the stand...all of the odd numbers should be facing the same direction and all of the even numbers should be facing the same direction.
Old 09-25-2011   #394
Put the heads on..... bolts need to be lubed with engine oil, then torqued in sequence 45 ftlbs 74 ftlbs 118ftlbs.
I numbered the order...the manual has them pictured as they sit so easy to get 6s/9s mixed up, etc
Threw the oil pan/front cover and breather on to cover up the engine......engine bag no longer fits
Old 09-25-2011   #395
a1991zr1
i am enjoying your posts and would be interested in the short block for sure
a1991zr1 is offline   Reply With Quote
Old 09-26-2011   #396
a1991zr1
Does any one have there old plenum and cam cover bolts that they would like to part with. I could put them to great use on a project and I do not like the look of the stainless allen bolts some of you do and I respect that just not my taste, so if you would like to part with these please let me know.
Old 09-26-2011   #397
I probably have most of them, if not all of them.
I need to check
Old 09-26-2011   #398
I have a complete set from my motor since I replaced them with the SS bolts.
Owosso huh? My wife's family is from Chesaning. Her uncle owned the Heritage House and Bonny Mill Inn. We go up there several times a year.
Old 09-26-2011   #399
a1991zr1
small world I use Manage Riverside Pontiac Buick Gmc and My Uncle was Gary Klien mayor of cheasning
Old 09-26-2011   #400
Should have posted that I am using Jerrys new head gasket, have an OEM set but wanted to see how these work....you also pick up some compression....
