Old 08-28-2011   #11
Default Re: FX3 shock actuators
If they are doing actuator rebuilds seems they would also have replacement planetary gears. Wouldn't hurt to give them a call.
Could be. I thought I would buy a used one and send old one and have it rebuilt and keep as a spare.
Old 08-28-2011   #12
Yun,
Thx for the inquiry. I'd like to see if I can sell them as a set first but I'll keep u in mind.
Old 08-28-2011   #13
Yun,
Thanks.
Old 08-29-2011   #14
Are they the same between the early years and later?
Also, any difference between the front and rear except for the wire length?
from 89-95 they are the same. No difference from front to rear except the wire length as noted. Short for the rear and long for the front. GC
Old 08-29-2011   #15
Thanks for the confirmation.
Old 09-07-2014   #16
Fully Vetted
Fully Vetted's Avatar
Is there any need to rebuild these if they are working correctly and the gears are all intact? $125 each is pretty salty if it's not needed.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 09-07-2014   #17
No. Don't fix em unless they break
Old 09-07-2014   #18
USAZR1
USAZR1's Avatar
This place is considerably cheaper and does great work,David.
Texas Track Works
3333 Suffolk Drive Suite 202
Fort Worth, TX 76133
817.926.8863
sales@texastrackworks.com
USAZR1 is offline   Reply With Quote
Old 09-08-2014   #19
Fully Vetted
Sounds good. Thanks, guys...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 11-06-2014   #20
564crewdog
FYSA…I spoke with the folks at Texas Track Works and unfortunately they informed me that they do not rebuild the FX3 actuators
564crewdog is offline   Reply With Quote
