Cleaning out the garage. The parts were from my 8000 mile 94 donor car. I have guessed at some of the prices so if you think I am out of line, just let me know. Shipping is extra.
Drivers and passenger seat tracks, the drivers frame is twisted, 150 Pair rear sway bar ABS pump and EBTCM 100 Rear factory rotors, mint, 40 Brake stainless flex lines 50 Oil cooler fittings in block 15 Oil cooler 125 Rear ABS sensor wires 1 94 air bag module 20 94 PKE module 75 90 FX3 module 100 94 LH air bag sensor, mounts to frame, 25 power seat harness and relay module 75 94 TPS interface module 20 94 power mirror switch 25 94 Full power switch and key 150 cruise module 20 94 LH power window switch 50 RH power window switch 25 94 ECM holder and wire cover 50 All AC heater vents 20 Interior air bag sensor #10210848 15 2 PKE antennas 10 Rear camber rod #10210848 20 Steering column parts: horn ring, multifunction switch, ignitions switch and key, turn signal switch 50 Rear camber rod brackets at diff 10 Gas filler boot 15 CHMSL ( white ) 40 90 AIR blower 20 94 wiper motor, no pulse unit 50 power steering cooler 100 power steering hoses, 1 low pressure, 1 high pressure 100 90 and 94 AIR valves 30 emergency brake handle 25 brake pedal 10 hood realease and cables 25 front and rear sway bar brackets 25 94 negative battery cable 25 3 wheel center caps and 19 lug nut covers 15 various plenum hoses and lines and fittings I think thats it ![]() Last edited by 65ZR1; 08-14-2011 at 01:44 PM. |
![]() Join Date: Jul 2007
are the joints tight on it? good shape? Shipping to 60172? will you take paypal?
What brand are the brake lines? Front and Rear? If Jeff gets the mirror maybe you can ship everything in one box. I live a mile from him.
![]() Join Date: Dec 2006
I'll take the gear shift knob. Paypal? My zip is 59405.
Jim |
The mirror is in excellent shape and the joint is tight. I will get a price on shipping for you.
CHMSL, is the paint in good shape? lens and lamps included?
#10 |
![]() Join Date: Aug 2005
Could I get:
Clutch line (20) 90 Vacuum pump (100) outside air temp sensor (10) Thanks - you're in Cambridge? I can come and pick this stuff up tomorrow if you like. Dwight |
