Old 09-19-2006   #1
ajaxajax2000
ajaxajax2000's Avatar
Default Telescopic antenna doesn't come up
Anybody know what can be the problem. I can hear the antenna servo working when I put on the radio, but the antenna stays down. (It worked properly until a couple of months ago)
Any hints on causes and cures?
TIA
Peter
ajaxajax2000 is offline   Reply With Quote
Old 09-19-2006   #2
Jeffvette
Default Re: Telescopic antenna doesn't come up
Internal ribbon is broken.
Easy 1 hour fix.
Old 09-19-2006   #3
ajaxajax2000
Easy 1 hour fix.
Ok, thank's. Sounds good. Now - what and where is the internal ribbon?
Peter
Old 09-19-2006   #4
Jeffvette
Write up
http://www.corvettemagazine.com/2002...tenna/ant1.asp
On the ZR-1, there is no panel removal. You can reach up from the back and undo all the bolts to get the unit down. When I get home I'll get you the part numbers for just the mast replacement.
Old 09-20-2006   #5
Jeffvette
12512900 is the part number I have. Should be less than 30 bucks,
Old 09-20-2006   #6
ajaxajax2000
Thank's a lot. That's what I call swift help. So I need to replace the whole unit? The article doesn't seem to go any further than the headline.
Rgds
Peter
Old 09-20-2006   #7
dbriana
Rgds
Peter
Try this one
http://zr1netregistry.com/antenna.htm
dbriana is offline   Reply With Quote
Old 09-20-2006   #8
ajaxajax2000
Great. Just perfect. Thank's!
Peter
Old 09-20-2006   #9
Jeffvette
Rgds
Peter
To advance the article it's in the upper left area with "Continue" or has 6 pages or so.
No you do not have to replace the whole unit, but you need to pull it out and take it apart and clean the gears inside of any substance. The part number I gave you was just for the replacement mast and ribbon assembly.
Old 09-20-2006   #10
ajaxajax2000
Got it. Thank's. I'll look a litle closer next time.
Peter
