Old 09-18-2006   #11
Jeffvette
Default Re: Help ! Oil in spark plug slot
You said cylinder #5 which should be the drivers side, but if it's the passenger side you do not have to remove everything on top to get the cam cover off. Just remove the passenger side coolant pipe coming from the injector housing.
Thanks for the compliment on the site. There are several projects I wish I had documented.
Rest of the tear down here.
http://www.pnwzr1.net/LT5_tear_down2.htm
Old 09-19-2006   #12
dlgeary
Yes, it's #5 and on the driver side. I was just wondering if I could get the cam cover off without taking off the plenum and everyting on top.
So you're saying that I can take the passenger side off but not the drivers side. without removing the plenum?
Thanks
Don
dlgeary is offline   Reply With Quote
Old 09-19-2006   #13
tccrab
tccrab's Avatar
Thanks
Don
Well, not speaking with any authority since I've not had the pleasure of taking the drivers side cam cover off... but will someday to get it powdercoated...
You will for sure have to remove the brake booster, but I can't tell for sure if the plenum has to come off to snake the cam covers past the air conditioner lines.
If you can get the cam cover past the air conditioner lines, then looks like the plenum can stay on.
Jeff? Johnny?
TomC
Old 09-19-2006   #14
Jeffvette
Jeff? Johnny?
TomC
Pick your poison. Remove the plunum to get the AC compressor out of the way for the cam cover to be removed, or evactuate the AC and disconnect the lines.
Then you still have to remove the brake booster and coolant pipe and move the Power steering pump stuff forward.
