Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Detailing, Cleaning, and Waxing
Old 07-18-2011   #1
cvette98pacecar
Default Detailing Engine compartment
Okay guys who has the best tool to get into all the crevices of an LT5 engine. Has anyone tried a steam cleaner and boxes of q-tips.
Old 07-18-2011   #2
Default Re: Detailing Engine compartment
your hand and a rag. anything else and you're going to be replacing the starter
Old 07-19-2011   #3
cvette98pacecar
That will take care of everything where I can get my hands. I need to get into all of the crevice's.
Old 07-19-2011   #4
i guess you could pull everything apart and pressure wash or steam it but that's just a guess
Old 07-20-2011   #5
cvette98pacecar
I have a commercial hand steamer that I have used for years, Just not on an LT-5 engine. I guess if it burns the finish that will give me a reason to have the Siamese intake done.
Old 07-21-2011   #6
scottfab
scottfab's Avatar
I use a pressure washer. If you stuff wads of plastic bags at the top
of the plenum to diver excess water you'll be fine. Small amounts of
water in the V aren't a problem. It's only when you exceed the rate at
which the drain hole can handle that you get in trouble.
AND of course you need to "blow dry" the compartment out when you're
done. I only know of one way to do that
PS take the plastic bags out before taking it out for the blow dry run.
Scott
Old 07-21-2011   #7
QB93Z
QB93Z's Avatar
My wife saw me struggling to get in the crevices and tight areas of the engine and bought me a package of wooden shish-ka-bob skewers. They are about a foot long, pointed at one end and blunt at the other. They are fairly soft wood so if you are careful you can clean crevices without damaging anything. You can also wrap a cloth around the skewer and get into medium crevices.
Old 07-21-2011   #8
Jagdpanzer
Jagdpanzer's Avatar
When I first got my Z I commandeered the wife's clothes steamer to spif up the engine compartment. It worked great for this purpose using distilled water together with windex spay on the extra grimey areas.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-21-2011   #9
RICKYRJ1
RICKYRJ1's Avatar
a steamer wil work fine to help loosen the grime up but be ready to wipe it clean & dry. What finish is on the engine? paint? powder coat?
Old 07-23-2011   #10
cvette98pacecar
[QUOTE=RICKYRJ1;119435]a steamer wil work fine to help loosen the grime up but be ready to wipe it clean & dry. What finish is on the engine? paint? powder coat?[/QUOTe
powder coated. I am going to try the steam. If it damages the finish it really doesn't matter as I am going to send the cam covers and intake to DRM for Black powder coating. All of the original engine work was done by DRM it has the same specification and was built the same time all of the Black Widow engines were built. I wonder why the original owner did not get the engine powder coated black at that time.
