Old 05-27-2011   #31
Daniel_Mc
Daniel_Mc's Avatar
Default Re: F!!!! Oil Leak...
Awesome! Thank you. I should be home in and able to start on the car in the next 2 hours. Great way to spend a Friday night huh?
Daniel
Old 05-29-2011   #32
Vikki
Vikki's Avatar
Hi, I'm new to the forum and have a small oil leak. I think it is coming from a pipe plug below the left cylinder head in the block. The oil drips on an O2 sensor on the left exhaust pipe creating a burning smell. Does anyone know what size Allen wrench will fit it?
Thanks in advance for your help.
Vikki is offline   Reply With Quote
Old 05-30-2011   #33
I had same issue with Cam Position Sesnor...new O-Ring and problem solved
Old 05-30-2011   #34
VetteMed
7mm or 8mm and yes oil can leak from there. if you can get to it.. let me know how, I want to check mine as well
It's 8mm bolts that hold that cover on. Once I removed my oil filter housing, to change out the leaky oil pressure switch, this plate is fairly easy to access. I don't see how you could get to it with the oil filter housing bolted in place, however. My bolts were snug, but not tight - I gave 'em an extra 1/4 turn with a box-end wrench.
Not a bad job:
Remove serpentine belt
Unbolt belt tensioner
Remove oil cooler lines
Unclip 3 electrical connections on filter housing
Remove bolts for oil filter housing (3 down low, one up high).
an $8 gasket from Jerry for the filter housing, and you're good to go.
Andrew
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 05-30-2011   #35
ittlfly
I'll drink to that....
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 05-30-2011   #36
Not a bad job:
Andrew
Thanks.. my next winter project
Old 05-31-2011   #37
Daniel_Mc
Daniel_Mc's Avatar
Well It took all of about 30 minutes with the correct tool and the sensor was changed and I haven't had another issue with the ZR-1 at all. Thanks for the help from everyone and Jerry Thank you for the part and gasket!!!!
Daniel
