Old 05-18-2011   #1
VetteMed
Default Beware charcoal canister breakdown!
As mentioned in my hi-miler thread, it would be a smart idea to check your charcoal canisters periodically. Mine started to deteriorate, and sent charcoal pellets all through the vacuum lines, solenoid, and presumably into the intake and cylinders as well.
I recently noticed that the engine would fire at the first crank, very unlike what an LT5 should be doing. I now figure this was due to constant fuel vapor venting from the tank into the intake, since the purge solenoid was lodged open due to charcoal pellets present.
New canister is around $60, new purge solenoid around $30. Guess it's still cheaper than owning a boat.
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 05-18-2011   #2
Default Re: Beware charcoal canister breakdown!
Andrew thanks for this post. Do you have any details on the parts number etc any install instrustions? Removal techniques?
Old 05-18-2011   #3
VetteMed
Sure thing.
The charcoal canister is located upside-down, behind the RH rear wheel, above the black plastic access cover. Note that this cover is not present in the equivalent location on the LH rear wheelwell area, so it should be obvious where the correct location is on the RH side. After removing the access cover, there's a friction type strap around the canister which can be loosened with a flat-bladed screwdriver, there's 2 spring hose clamps to remove, and there's 2 plastic clips over the "top" of the canister which is actually the part closest to the ground in this case. incidentally, it's this upside-down mounting that makes failure of the canister particularly likely to cause the dissemination of charcoal particles.
GM PN for the canister is: 17090139
I purchased an aftermarket (Standard Motor Products) CP1031 for a few bucks less.
UPDATE: The Standard Motor Products canister is the OEM Rochester unit, with a GM part number on it.
Replacement of the purge valve is only needed if you find charcoal particles in the lines. it's located under the plenum, just aft of the 2 large breather hoses. It's secured by 2 - 8mm bolts.
The purge valve PN is 01997201 for ACDelco. Note that the new valve does NOT come with the bracket, you must save and reuse your original.
Old 05-18-2011   #4
Originally Posted by VetteMed View Post
Sure thing.
Awesome thanks Andrew.. I will replace for GP. Where did you order your aftermarket canister from?
Old 05-18-2011   #5
VetteMed
Rockauto, under 50 bucks before shipping.
-Andrew
Old 05-18-2011   #6
Ordered thanks
Old 05-20-2011   #7
VetteVet
VetteVet's Avatar
Same thing happened to mine. Advance Auto had a replacement for 52.99.
VetteVet is offline   Reply With Quote
Old 05-20-2011   #8
Ive got something I need to take a look at,whenever I put the car in the garage I can smell gas at this corner of the car.If gas fumes flow through the canister shouldn't there be no smell?
Old 05-20-2011   #9
Daniel_Mc
Daniel_Mc's Avatar
I was going to check the one in the 91 and found the line that was caped off and in the rocker panel went to this canister? What would the reason be for bypassing this?
[COLOR=black]Daniel McGuffee [/COLOR]
[B]1989[/B] Red Coupe #10166
[COLOR=black][B]1989 [/B]Black[/COLOR][COLOR=black] Coupe #23990[/COLOR]
[COLOR=black][B]1991[/B] ZR-1 White #1639[/COLOR]
[COLOR=red]FRANK APPROVED ZR-1[/COLOR]
[B][COLOR=red][COLOR=black]1996[/COLOR] G[/COLOR][COLOR=blue]rand[/COLOR] [COLOR=red]S[/COLOR][COLOR=blue]port[/COLOR][/B] [COLOR=black]Coupe #564[/COLOR]
"It's not about the car, it's about the people..." DJ
Don't forget to support your [URL="http://corvettemuseum.com/"]National Corvette Museum[/URL]!!!
Old 05-20-2011   #10
If it is working correctly.. then yes, no gas fume smeel
