Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 03-06-2011   #11
ZR-1nce removed
ZR-1nce removed's Avatar
Default Re: WAZOO DOES IT AGAIN!!!
Good job guys. Sorry I had to miss it, but occasionally us Civil Servants have to go to work. Hopefully I'll catch the next WAZOO event. I see Ricky has competition now!!!!
90 ZR-1 #0951 Bright Red (sold)
06 Z51 MN6 Velocity Yellow (sold)
2023 C-8 Z51 ELB
ZR-1nce removed is offline   Reply With Quote
Old 03-07-2011   #12
Originally Posted by Scrrem View Post
Phil, in that department, the team was unsuccessful (Sorry I let WAZOO down). We only got 30, but Stage 8 bolts were not used for this job, so my custom header wrench was useless. It also took half the time leaving that bolt out on each side.
Ted, Yun did turn some wrenches even in his fancy duds!!!
Rich
I also downed one cannoli.
Old 03-07-2011   #13
cloudshe
thanks, david!
appreciate the introductions & the info on WAZOO!
george's garage is quite motivating! wish i had a little more property to do the same. looks like the header session was a success, nice work!
thanks again, hope to see you again soon
bruce
cloudshe is offline   Reply With Quote
Old 03-07-2011   #14
I have a bad case of 'garage/shop envy' ... see I'm green with it.
No kidding that is a nice garage/work shop.
I was trying to figure out if that whole exhaust system was chrome, that is sweet!
A question for you guys. I looked at my OEM exhaust manifolds, once, and the factory didn't get near all the bolts in all the holes. Is this a critical thing to keep in mind when installing headers on an LT5?
TIA
Old 03-07-2011   #15
Jagdpanzer
Jagdpanzer's Avatar
Tom,
Not critical however, an achievement one can take some pride in having faced the challenge and prevailed spite of the difficulty involved. Plus gives you somthing to brag about to all the guys who couldn't get all 32 screwed in.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-07-2011   #16
ScottZ95ZR1
ScottZ95ZR1's Avatar
I'm with you Tom, I thought I was looking at chrome, too. The shine on that exhaust system is amazing. I look up at mine now in disgust.
ScottZ95ZR1 is offline   Reply With Quote
Old 03-08-2011   #17
TIA
Tom,
I will let you in on a secret. Jim and I found a high temp epoxy... We are not going to tell Phil about this. Oops! Did I let the cat out the bag???
Old 03-08-2011   #18
LT5-1935
Here are a couple of pictures of the complete exhaust (just hanging not tight)
LT5-1935 is offline   Reply With Quote
Old 03-08-2011   #19
ZR1@gmx.com
Tom,
Where would one get this hi temp epoxy???
Pete is not looking!
ZR1@gmx.com is offline   Reply With Quote
Old 03-08-2011   #20
Scrrem
Scrrem's Avatar
Looks great George, can't wait to hear it!!
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
