Thanks,
Some more ignition stuff: I believe the 1990 LT5 engine was released prior to Northstar. One difference between Ignition modules. Northstar ignition used 2 VR crank sensors with 24 pulses (or was it 32 ?) per revolution rather than the 1 sensor and 9 pulses of LT5. The ignition module uses suface mount components and is potted. Than a lid is sealed over. Typical sealing of igniton modules of the time not designed to be serviced. A serious electronics expert may want to try. Another thing it contains is a Motorola processor with EEPROM. If it lost its memory I do not know what one would do. the whole module was made by Motorola who supplied it to Delco Remy who supplied it to the Chevrolet group. It does have a back up mode that allows ignition output if communication is lost from the ECM. I would be happy to help discuss some after market system ideas such as MSD? I'll check back Wed. |
![]() Join Date: Mar 2007
Any comment on the trigger system that was used on the two bentley motors?
Here is a note on internet settings, be sure to check remember me...and check cookies settings: The privacy settings for your web browser may be set too high to allow the message board cookies to be set on your computer. We have noticed that when users are being upgraded to Internet Explorer 8 the privacy settings are being reset to a higher level. You may need to lower those settings. For Internet Explorer browser go to Tools > Internet Options > Privacy and set the slider to low.
LT5,
The approach that I took in adapting LSx coils was to try using the IM as the sequencer. Rather than have the IM actually fire the coil through ground signal, we built a circuit that converted the ground into the triggering signal used for the LSx coils. I built separate power and ground circuits for the LSx coils. They suck up quite a bit more power than is provided LT-5 coils. Each side of LSx coils needs a 20amp fuse. I was using the 2nd gen LSx truck coils which are the ones all the C6 guys rave about due to the 120k volt spark it throws.The motor would "start" but I suspect that the IM could not complete the timing "hand-off" after reaching the 400rpm threshold. I was able to achieve a Start to On transition several times with the 1st gen truck coils I had. The first time it ran, I found that I had two of the coils reversed in terms of sequence causing it to run rough. Once the coil sequence was corrected, motor started and idled smoothly but then came to a halt after blowing the 10amp fuse in the secondary injector circuit which powers the LT-5 coils. I then built harnesses to completely separate the power and ground circuits for the LSx coils from the LT-5 circuit. In this configuration, the motor would only Start but not transition to On. |
