Old 11-08-2009   #11
Sgreg
Sgreg's Avatar
Default Re: Anyone have experience with wheel spacers ?
Sgreg,
I asked the question because I had been investigating the same issue while thinking of Z06 wheels. Locobob may care to comment but my impression was that an adapter should be used with any thickness greater than 1/2". Also, there's the issue of hub and wheel centric.
I have never heard of the 1/2 in. rule regarding spacers and adapters. Seems many are using quality spacers and studs in larger sizes, i.e. Jeff at 20mm ?
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 11-09-2009   #12
Got mine from here on reference from WVZR1:
http://www.wheeladapter.com/fred_goeske.php
I got a set from this guy.16MM for the GS A molds,hub centric to the car and to the wheel.A very nice set for $175 I think is what I paid for them,made to order.The longer wheel studs I got from the dealer.At some point Ill put the 91 wheels back on the car and would like to keep the longer wheel studs in place so that I can use the GS wheels later on down the road. I thought Id get a new set of wheel hubs and just have 2 sets,one with the longer studs and one set with the stock studs and change the hubs to the corresponding wheel,wrong.To get around not having to change the wheel studs everytime I change wheels I will get a spacer made just wide enough to allow the longer studs to work within the lugnut covers on the 91 wheels.[IMG][/IMG][IMG][/IMG]
Old 12-29-2010   #13
ZR1North
Guys,
Anyone know for sure what the center bore is on the rear 11" wheels? I am ordering 16mm spacers and cannot easily get at the car at the moment to make a measurement. It seems like every other spec is available on the wheels - except this!
Much appreciated
ZR1North is offline   Reply With Quote
Old 12-29-2010   #14
Check Wheelapdapter.com
Old 01-03-2011   #15
ZR1North
Originally Posted by ZR1North View Post
Guys,
Much appreciated
Thanks for your help on this guys. Spacers are ordered. By the way, if anyone is looking for the Center Bore, it's 2.75 inches (69.85mm).
