Old 12-07-2010   #1
Nacho_ZR1
Default Extrude Honing?
What are ya'lls opinions on extrude honing? I see alot of intakes are ported by hand but won't extrude honing provide a more consistent and powerful result?
Nacho_ZR1 is offline   Reply With Quote
Old 12-07-2010   #2
Default Re: Extrude Honing?
My intake was extrude honed, was only 34mm......I opened it to 36MM and put down 391rwhp with no tune
Might as well pack that intake an send it to Crystal Lake, Il for the most hp per $ around(shameless plug).
Old 12-07-2010   #3
Are you sure yours isn't ported? (by looking at mods)
Old 12-07-2010   #4
Nacho_ZR1
Wow that's like almost 80hp with the honing ! Did you have any other mods to achieve that number? Also, how long did it take for the porting work to get done and is the pricing similar to what a port done by hand costs?
Back in the old days, extrude honing was the way to go. Intakes and heads were extruded and the results were always spectacular - at least on Mustangs. Just not sure why I haven't really seen it mentioned here with regards to the ZR-1...Seems logical to me
Old 12-07-2010   #5
Nacho_ZR1
Well not quite sure how to tell? I'll see if I can get a pic of the intake when I get home Thursday night (working out of town) and post it here. I would assume the insides would be smooth as glass???
Old 12-07-2010   #6
If its extrude honed you can crack the TB and see inside is smooth as glass
Old 12-07-2010   #7
I used EH on the Xfire manifold of my 84. I think it worked there but it wasn't cheap. I understand the people at EH are reluctant to do LT5 plenums because runners may separate from plenum due to high pressure.
Old 12-07-2010   #8
Aurora40
Aurora40's Avatar
Talk to Scott, hiznhrz. His car had EH heads, I/Hs, and plenum.
Old 12-07-2010   #9
seems like a lot of money for not much gain
Old 12-08-2010   #10
Locobob
The Extrude Hone process has both positive and negative aspects.
It would work well inside the plenum which is hard to access by hand.
Smooth as glass... well it looks nice but a high polish is not helpful in promoting intake air flow.
Extrude Hone can not target specific areas - like injector bosses for example.
Bottom line: generally you'll get better results with properly done hand porting.
Robert
