Old 11-15-2010   #241
Default Re: LT5 Assembly Project
Just an FYI, i bought a full set lifters off ebay(only paid $32)....HT-2236 Sealed Power....machine shop advised they will not work with heads.....checked cross reference today and it shows this is an LT-5 lifter....
Will post pics tonight.
Lee
Old 11-15-2010   #242
limey
The HT-2236 require shims, they are shorter than the stock GM ones, although they can "fit" they don't.
limey is offline   Reply With Quote
Old 11-15-2010   #243
Pete
Pete's Avatar
When you say shorter,how much shorter.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-15-2010   #244
Actually the stockers are shorter.....will post pics
Stock on left:
-stock on left shorter
Old 11-15-2010   #245
Brought the heads home today:
Reshaped IH bolt boss....
Primary is 35MM at entry(which is actually .5" into the head, drops to 34.5 1/2 way through, 34MM into the bowl
Secondary is 36MM at top narrows to 34MM into bowl.
Old 11-16-2010   #246
tpepmeie
Stock on left:
Are you certain? The INA lifter on the left is almost definitely aftermarket, and looks similar to the lightweight buckets I am running in the 427. The height difference is solved in my case with +1mm longer valve stems.
Weigh them up... you'll find the oem piece around 75g, and the INA one considerably less, depending on which design.
Old 11-16-2010   #247
Jagdpanzer
Jagdpanzer's Avatar
Todd
Will your lightweight lifters work with stock valves?
Old 11-16-2010   #248
tpepmeie
Probably not, unless you do a valve job and sink the valves, or use shims (lash caps) on the tips.
Old 11-16-2010   #249
Those are the lifters that were in the heads, and also the only ones that worked with the valves....
Old 11-17-2010   #250
I think there is plenty of flow as is....need to consider one side was over 40mm at the top
Both sides are ported
I am not drilling for oil or anti-freeze
Not drilling for oil...or antifreeze?? What fun is that???
I'd be tempted to open it up at the bottom, just a tad, which can be done w/o significant danger of punching through. (I'd tell ya, but Marc would have to kill me!) How some ever, proof is in the pudding/dyno/trap time, as it were.
Question: Did you have to have the IH's built up as well? I assume so, if the IHs were port matched to the "before" heads. Or, did you just buy the heads with intention of using some other IHs? Are the IHs siamesed as well?
It will be interesting to see the results! Is there another 500+ hp FBI Z in the making?
P.
