Old 11-14-2010   #1
Polo-1
Default Fire Sale List
Here is the first list. Prices are cheap (for LT5 stuff )
Interior parts:
94 A/C controller-$25 -Kurt
94 A/C black box with vac hoses-$25-Kurt
Rear compartment door assemble-$15-Phil Jag
Rear tray compartment-$10-Phil Jag
Black ZR-1 floor mats front and rear-$45-VettMed
Black ZR-1 sill covers-$15- David
Seat back plastic bezel in GM bag-$25
94-95 Center Dash Bezel ? in GM bag- $175-Phil Jag
Shift/Ash tray bezel- $25-Phil Jag
Instrument bezel-$15-Phil Jag
94 Red driver side door panel-$75-Ricky
94 Red under dash driver hush panel-$25-Ricky
94 Red under dash passenger hush panel-$25-Ricky
94-95 head light/fog/abs switch assembly- $100
Body Parts:
91-94 both gills- $100-gen2rt -jack
95 passenger side gill-$50-Ricky
Rocker panels both-$150-Xfire
New emblems gas/hood-$25-Phil Jag
Original metal emblem gas/hood-$15- Ben PAID & SHIPPED
ZR-1 emblems 6 AB, 3 Polo - $40 ea- David 2AB
Corvette emblem 1 AB, 1 Polo-$50 ea- David 1AB
Outside door handles both-$25-Phil Jag
Bronze top-$150-David
Third brake light lens-$10
ZR-1 windshield late 93 date code-$500- zrss Jim and 402 right buddy :-)
Suspension Parts:
Coil over DRM kit 425/275 with FX-3 shocks(500-or 1500 miles) $1000 -David
DRM relocate brackets new -$150-David ??
1 90-92 rear shock-sold
Rear knuckles -$25
Rear brake caliper holders-$25
Motor Parts:
91 block LA sleeves fresh bore/hone 4.010 ready to build-$1500
Oil pump-$150- Dynomite
Pan assembly pickup/tray-$250
Front cover-$100-Dynomite
Alternator AC/Delco new-$125-Russell
Alternator used-$65
Breather box and baffle-$125
A/C compressor with clutch 91-95 - $250
Power steering pump 91-95 - $75
Stock cams 91-$200 ea
Heads no cams 91-$ 500 ea- Dynomite both L&R
Plenum 91-$300-Locco
Injector housings 91- $125ea-Locco
Throttle body 91-95-$300-Dynomite
Air horns 2-$75 ea-1 Dynomite 1 Locco
350 cranks 2 -$75 ea 1-johnny phrogs
350 piston/liner/rods under 10k miles-$600- jeff f
Balancers new/used- $100-$65 (used match to crank johnny phrogs) 1 jeff
Chain guides all with strips-$100ea
Chain guide wear strips all-$75-jeff
Main bearings new coated-$650
Reconditioned GM?s coated- $450
Pulleys Randy Woods-$50-Phil Jag
Oil cooler line kit-$75-Xfire
Secondary parts new/blades/actuators/levelers/everything from heads-$150-Dynomite
90-92 exhaust manifolds stock cats -$175
91-92Heat shields-$25-Ricky
Plug wires LT-5 NEW in the box-$300-Dynomite
Plug wires new Delco-$50
Smog pump /tubes/lines 92 -$50
Bell housing with fork-$75- Phil Jag
Misc parts:
Spare tire-$25-johnny phrogs
Spare tire holder and brackets-$25-johnny
Spare tire bag -$50- 91 vettezr1 Todd
License plate holder rear-sold
Jack and bag-$15
SS brake lines front-$25-Dynomite
Fuel lines from motor to frame with filter-$25-VetteMed
Stock filter lid metal-$5
3:73 gears new in box Viper with Speedo gear -$ 150-Phil Jag
Samco intake boot in bag-$100 - Phil Jag
Speedware Motorsports Harness bar with camera mount- $250 Best bar out there.-Phil Jag
94 used Master brake cylinder-$25
91 used Clutch master and slave with line-$50-johnny phrogs
Corsa?s-$500-Aaron ammrpm
Fuel pump assembly stock used -$75- Russell
Pizza box 90-$100-ZeeAreOne
Pizza box 91-$100-Limey
Rear ABS sensors-$25 ea
Old 11-14-2010   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Fire Sale List
I'm interested in (will take):
Please PM the total with shipping.
Thanks,
Phil
Last edited by Jagdpanzer; 11-14-2010 at 03:02 PM. Reason: Added "(will take)" clarification
Old 11-14-2010   #3
VetteMed
New hood/gas emblems if jagd passes
clutch master & slave with line - is this used or new? miles?
same for brake master cyl?
stock filter lid
fuel lines from frame to motor
Oil cooler line kit - is this oem, nos, aftermarket, used?
What color are the floormats?
_________
Updated 2:22PM, only interested in floormats and fuel lines. All other items I will pass.
Old 11-14-2010   #4
Polo-1
Alright guys....
I'm getting phone calls and pm's.... Lets try to keep it out here, for my sanity..
Please no paypals yet.... If you lay claim to it here I'll hold it for you.
Old 11-14-2010   #5
Polo-1
anything "91" part is from running motor with 50k on it.
The clutch Mater and slave/line is still all together uncorked from the running 91.
Same with T.body. all sensors and lines are still on it.
Old 11-14-2010   #6
Polo-1
Yes.
I have not looked at all the gaskets and other stuff...
Old 11-14-2010   #7
HIZNHRZ
Polo, I'll take the floor mats for $45 plus shipping.
Old 11-14-2010   #8
damn this is what i get for sleeping in...I was looking for a rear plate frame
Old 11-14-2010   #9
Polo-1
lets keep it out here.... Email from David @10:43 am
Bronze top-$150 (depending on shipping)
ZR-1 emblems 2 AB,
Corvette emblem 1 AB, -$50 ea
Ricky will want these below
Old 11-14-2010   #10
RICKYRJ1
RICKYRJ1's Avatar
I will take the red hush panels both sides & door panel, if they are for 94-96. Thanks
