Old 09-14-2010   #1
dallas
Default need some fuel "O" rings
I need the "O" rings for the fuel block connection to the fuel rail (#1 and #2 on the FSM drawing). I could probably use a few of the IH primary (large) "O" rings since I found 1 leaking and encrusted with the same gunk that was on the #1 and #2 "O" rings. A few injectors look like they could use new #86 "O" rings, too.
I checked a few parts houses and they didn't have them. Our local Chebby dealer said they were only available in the aftermarket, and their supplier was EXTREMELY expensive.
So...do any of you have any of these available for sale?
dallas is offline   Reply With Quote
Old 09-14-2010   #2
Default Re: need some fuel "O" rings
Maybe Jerry?
http://jerrysgaskets.com/store2/root/
http://jerrysgaskets.com/store2/root...roducts_id=400
Old 09-14-2010   #3
Yeah I think Jerry has some
Old 09-14-2010   #4
Thanks to everyone for the referrals!
Look on pages 3 & 4 (link to page 3 as follows)
You have a choice of Buna or Viton-A, which ever you prefer.
http://jerrysgaskets.com/store2/root...ort=20a&page=3
Also have complete fuel system sets in Buna or Viton-A, and have also added some different "Kit" options in the Gasket Kit sub-category.
http://jerrysgaskets.com/store2/root...cPath=16_19_20
Old 09-14-2010   #5
VetteMed
I replaced mine with Jerry's, top quality stuff as always!
Old 09-14-2010   #6
dallas
Thanks, guys. That's what I need. Thanks for the page, Jerry.
Old 09-14-2010   #7
dallas
Oh....speaking of gaskets/seals: when I pulled the plenum this time there was a lot of grunge stuck to the underside of the air intake horn and TB area. The engine is normally very,very clean and hadn't had any oily crap that I could really see before I stopped driving it. But it was pretty grimy and even the valley had a layer of oily/grungy dirt on it. That's not normal for my car, so I'm wondering if there is a smog line or seal on the front of the engine that might be leaking.
I know I need a new oil pressure sending unit, but I think this is different.
Thoughts??
Old 09-14-2010   #8
jrd1990zr1
jrd1990zr1's Avatar
Are all the bolts tight on the crankcase ventilation cover? Mine was seeping, made a mess. Jerry has that gasket too.
Also check the 3 bolts on the oil filter housing.
