Old 08-04-2010   #11
pantera1683
Default Re: Rear hatch weatherstrip.
Originally Posted by zr1nsxgto View Post
I think I need to get in contact with a applications specialist at 3M and see what is the best product for gluing the corners. I can make a fixture that would accurately mitre cut a 1/16 or so off of each cut to get into virgin material. Then hold the strip in the fixture to apply and hold the glue while it cures. I'm fairly certain that 3M developed the adhesive that was originally used and they probably have developed a superior product since then.
I used to work in a speaker manufacturing plant and we used a variety of adhesives for a gazillion applications. One of those applications was gluing the rubber surround of a woofer to the paper cone. This was done with a product that was referred to as "black max" and stayed pliable for the life of the product. These cones were subjected to a battery of environmental stress testing---salt spray, UV resistance, heat-cold survival, etc. I think that product might work well for the weather strip. Accurately cutting and regluing is what will determine how well it works.
Sounds cool, keep us updated.
Old 08-05-2010   #12
LGNDLT5
LGNDLT5's Avatar
All you need is 3M Black weatherstrip adhesive in a tube. Available at quality auto parts stores etc. This is the stuff it was originally glued with. Made for this type of application and works great. You must follow the instructions though. Not a big risk at $5-$6 for a tube. John
LGNDLT5 is offline   Reply With Quote
Old 08-05-2010   #13
I once built a wet-suit jacket from scraps of wet suit pieces - "my coat of many colors". The wet suit rubber is very similar to weather seal, and I've always wondered if some of that wet suit repair cement you get at a dive shop wouldn't put the ends of these weatherstrips back together.
Not too many "dive shops" around here, but I'm sure one could get a tube on line somewhere and give it a try??
If that danged stuff works as well on weatherstripping as it did my wet-suit, you can "set it and forget it" and save a buncha bucks. Anybody got some of that rubber cement????
Just a thought.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-05-2010   #14
bobbyhi
bobbyhi's Avatar
Just a thought.
P.
I think they guy before me tried the rubber glue and after so many years that it has "let go". I'll probably buy the after market and put that on during the winter (heated garage!!). Thanks Paul..............
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 08-06-2010   #15
soslow
soslow's Avatar
I had the same problem at the corners, but the rest of the weathstrip was perfect. I just repaired the corners by taping it together with the black tape thats sold to repair radiator hoses with. It is waterproof and stays put. If you trim a piece to fit just so, it looks pretty good, holds the edges together and blends right in so as to be almost unnoticeable.
soslow is offline   Reply With Quote
Old 08-08-2010   #16
Hammer
Hammer's Avatar
Talking Re: Rear hatch weatherstrip.
I used the same piece for the hatch weatherstrip and it works great. Over two years now and no problems at all.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I]
[I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I]
[FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT]
[I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B])
1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I]
Old 08-08-2010   #17
Heres my repair.Ill replace it with a new G.M. piece here pretty soon.[IMG][/IMG]
