Old 04-27-2006   #11
blackjack
Default Re: Throttle body plate
you could also try a large gasket scraper...works for me....just be gentle...
ill be waiting for my check....hehehe
blackjack
91/1735
blackjack is offline   Reply With Quote
Old 04-27-2006   #12
tf95ZR1
tf95ZR1's Avatar
Originally Posted by 95ZR1#418
I knew someday someone would have the answer. This is obviously it. It's like how could I be so stupid not to see it.... I gave up-. I'm going to change it right now!!! Thanks a million Yes, I'm embarrassed & so should be the entire Net for how many times I've got no reply.
Gee.... if only I knew your name I'd send you a $1000.00 for the answer, but I checked your profile and your anomonous, oh well, maybe next question...
Thanks allot man...
The name is TED FEDER
I could use the $$
Do not send it to my home- the wife will get it and spend it (and more) .
seriously, I can't tell you how much I have learned from the net.
Invaluable. Just spreading the info.........
Old 04-27-2006   #13
tf95ZR1
tf95ZR1's Avatar
oops
Old 05-01-2006   #14
95ZR1#418
95ZR1#418's Avatar
Originally Posted by tf95ZR1
Hey Bob
Maybe instead of trying to pry the plate off, you could thread a couple of
larger bolts into the bolt holes of the plate and tap it off. I bet once the
"seal" is broken it'll come off. You will need to get the old gasket off........
Good luck!
Well, I did get to it tonight. Tapped one hole each end, just into the top plate holes then inserted very short bolts, just a couple turns. I could then get a screw driver under the bolt head and pry against the TB and up it came. I waited at least a couple years to get this done not wanting to chance chipping paint or ruining the stock plate.
Thanks for that tip Ted!!!
The new LT5 Billet plate looks great there compared to my work bench....
Later-Bob :D
[IMG]http://www.axoplasmic.com/800x600/toponzr1.jpg[/IMG][IMG]http://www.axoplasmic.com/800x600/topoffzr1.jpg[/IMG][URL="http://axoplasmic.com/AXOPLASMIC/ZR1.html"]My '95 ZR-1 Home Page[/URL]
95ZR1#418 is offline   Reply With Quote
Old 05-01-2006   #15
carter200
carter200's Avatar
Bob,
Glad you finally got to mount the plate and that you are pleased with it. =D> If you need one to fill the dust outlined spot where the old one was I have more Take care, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
