07-19-2010 | #1 |
help on keys
i messed up and lost the keys to my car . is there a way i can get copys from a dealer and if so how does one go about doing it .thanx for any help you can provide
07-19-2010 | #2 |
Re: help on keys
Any Chevy dealer can help you.
Bring your original set and a copy of your registration (just in case). |
07-19-2010 | #3 |
Re: help on keys
wish i could bring the original set ,but only had one set and they are gone now , do i have to go out and buy new locks or does ,can the dealer set me up with new keys ?????????????
07-19-2010 | #4 |
Re: help on keys
You will need proof of ownership and the VIN. A Chevrolet dealership can get the VATS key code from your VIN number.
07-20-2010 | #5 |
Re: help on keys
is the vats key code the code for the little pellet on the key or does it include the info to reproduce the whole key . i had previosly got the correct blank keys with the right pellet code for both my zr1s. just hadnt gotten around to getting them copied . i am getting copies made for my 92 tomarrow .i have the correct blank for the 90 but nothing to make a copy from ??/ thanx for the info so far.i guess i will fess up as to where i lost the keys , at one of nevadas finest brothels. guess more than my business went into the hole
07-22-2010 | #6 |
Re: help on keys
Call the dealer and see if they can still get the key codes.
im not sure if they still have the stuff from back then. I do have an ignition switch with key if you need one Id sell if not to hard to get in and swap them then you can get the key cut with the correct pelet for your car with this lock cylinder. the code has nothing to do with the switch its all in the BCM.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
07-23-2010 | #7 | |
Re: help on keys
If you already have the correct blanks, you're over the biggest hurdle. The VIN should provide the Dealer with the key cut info.
07-23-2010 | #8 |
Re: help on keys
guys tahnx for all the insight . i guess i am glad i have the right pellet blank. i will try and call the chev dealer in reno tomarrow and will let everyone know what transpired .
07-23-2010 | #9 | |
Re: help on keys
07-23-2010 | #10 |
Re: help on keys
I had my dealer check the resistance of my key (no charge) and I wrote it down for future reference. I also ordered a blank key with correct resistance from MidAmerica or Eckler's. I believe it was about $14. I would suggest this to all who have not done this yet. I was a boy scout many moons ago and still remember the motto: "Be Prepared".
JB 1990 #148 Red/Saddle Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice :cheers: Last edited by John Boothby; 07-23-2010 at 11:14 AM. |
