Old 06-17-2010   #1
Belsy
Belsy's Avatar
Default Plenum tools
About ready to pull plenum, what is being used for the torx in those tight areas? Seems like a deep / long head is nec. Also any favorites for scanners from your experience? OBD 1 & 2 needed?
Thanks for any input,
Gene
Gene in Fl. :handshak:
______________
95 ZR-1 #399
Dunn heads
X-pipe w/3"
misc. mods
Belsy is offline   Reply With Quote
Old 06-17-2010   #2
VetteMed
Default Re: Plenum tools
Gene, I'm not too far from you (Micanopy FL), if you want, I can lend you the long bit I have to un-do the torx bolts in the plenum. I think it's a T35 torx, I bought a Snap-On brand one for around $20 so it might not be worth the gas to drive to pick it up
The system is OBD I.
Old 06-17-2010   #3
rkreigh
the top tool has the same torx shaft and will work in a pinch
I've had a hard time finding the long shaft torx tools
any place other than snap on? good tools but a bit pricey
95 390 LPE ZR1 (505 rwhp)
Old 06-17-2010   #4
ittlfly
I bought my long shank torx T40 @ this vendor. This is will make life easier.
http://www.toolsource.com/drive-long...t-p-57355.html
1994 ZR-1 # 0102...SOLD
ittlfly is offline   Reply With Quote
Old 06-17-2010   #5
gbmidyear66
I just used a short Torx bit from an "all in one" had driver set which came with an adapter that makes it compatible with my 1/4 drive tools (I used a long 1/4 inch extension on between the runners)
AutoXray 600 provides full live data for OBD 1 and 2, Innova 3120 does not. Anyone wanna buy an Innova 3120 :-)
[SIGPIC][/SIGPIC]
1990 Corvette ZR-1 #2824
4.10's, Custom PROM, Flowmaster, Top End Port
NCRS BC Chapter
Old 06-17-2010   #6
ZR1Vette
ZR1Vette's Avatar
This might be of help... I posted when WAZOO had a plenum pull gathering>>
http://www.zr1.net/forum/showthread.php?t=7614
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 06-17-2010   #7
John Boothby
John Boothby's Avatar
I bought my long shank torx set from Autozone. Got the job done! Also buy a wooden handle for a hammer to hold up the plenum while you disconnect the ignition module wires and front vac line.
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
Old 06-17-2010   #8
jrd1990zr1
jrd1990zr1's Avatar
Matco Tools has a long bit. I think it cost me about $17.00
Hammer handle is a great idea. Worked good for me.
Old 06-18-2010   #9
Belsy
Belsy's Avatar
Thanks guys for the info !! The scanner is an item I have been considering for awhile for other cars also, so a popular & reliable unit will be helpful ? Can I get real codes with the paperclip method? I have service manual 1 & 2 for the '95 do I need anything else to cover?
Thanks again,
Gene
______________
95 ZR-1 #399
Dunn heads
X-pipe w/3"
misc. mods
Old 06-18-2010   #10
ittlfly
I bought a AutoXray scanner when I bought my 94. It came with the ''OBD I'' cable so I had to order a separate OBD II cable to fit the ALDL. Works fine, ''real time'' codes, snap shot in time sensors readings, yada yada......and the price was right.
I'm sure others will chime in as there are a lot of choices out there.
