Old 06-16-2010   #11
Default Re: Emissions -- Bah Humbug!
Originally Posted by SoCalZR1 View Post
Thanks for the input Jim. I am in Tustin so the 10 mile radius should mean the same limits. :-)
I was told that the standards changed a few months ago. It is a little hard to believe that we need to meet higher standard than last year, but this is California I guess.
I too have heard that the standards have changed.This doesnt seem right,how are these older cars supposed to keep up with tougher standards,remove them from the road?
Old 06-16-2010   #12
Embrace Change
Old 06-16-2010   #13
SoCalZR1
Embrace Change
You are funny!!
SoCalZR1 is offline   Reply With Quote
Old 06-16-2010   #14
Embrace Change
Embrace change my a$$.When you have your car planted in the garage because you cant drive it anymore,remember this.
Old 06-16-2010   #15
SoCalZR1
One way or the other this ZR-1 is getting on the road. But I agree, it is &$#&^%# change. Hard to believe they can change the standards required for a 20 year old car.
Old 06-16-2010   #16
ittlfly
I'm going to PM you witha suggestion where you might want to take your car for some ''help'' in passing smog in the So Cal area.
ittlfly is offline   Reply With Quote
Old 06-16-2010   #17
gbmidyear66
Mike, an Innova 3120 will not read live data (e.g. O2 sensors) on an OBD 1 car - ask me how I know...
You need an AutoXray 6000 (for sure), or an Actron 9150 or a Craftsman 2500 (I believe the latter 2 will).
Old 06-17-2010   #18
SoCalZR1
I'm afraid to ask but I figured that was the case. I was looking at the AX 6000 since it is easy to get at a good price. It might help me pin down this problem. Thanks for the info.
Old 06-17-2010   #19
Mike, I'm glad that some one had the answer about the scanner, because I didn't. That's weird. I thought all scanners read live data? Otherwise what's the use of the tool?
Look, I don't want to be a wise guy on this but the plug gap should be set back to OE specs for the testing. The techron will help keep the injector tips clean, I use it once every two months in my car.
Also, take out the PCV's and shake them. If they don't make a clear metallic clicking noise, change them out. Also, make sure the PCV rubber connections are air tight. Also, check the MAP hose for oil build up, that needs to be clean.
You are correct on the O2 sensors, at 20 yrs old they proly are a bit tired. I changed mine out for the same reason.
Old 06-21-2010   #20
SoCalZR1
Default Re: Emissions - Updated with new California info
Update...
I have managed to talk to a guy at BAR (Bureau of Automotive Repair), we have it all here in California.
If you passed smog in 2009 you may not next time its your turn:
- Emission standards on our cars changed this year. I was not imagining it. The max levels have been changed to what the car had to meet as new. For example, what was an HC limit of 110 PPM last year on my 1990, is now 77 since that was the threshold on the car when new. I managed 70.
- I passed NO the first time and failed the second. The BAR guy looked it up. He knew my results and he knew the temperature that day where I had the test done. He says the tester did not follow proper procedure. When the ambient temp is above 74 the tester must use a large fan to provide airflow and keep the car as cool as possible. He did not and so the BAR tech believes that is why NO failed since combustion temps would have been high compared to real world conditions.
- I mentioned that if it turns out the CATS need replacement they are not available anymore. I was told to call the State Contracted Parts Locator ( 800-622-7733) and they can confirm and issue a certificate that parts are no longer available, and then a "referee" will issue you tags for two years with no smog test. There is one exception... there is a new "visible smoke test" that must be passed. If it fails then no tags can be issued until fixed. Here is a link to the process: http://www.smogcheck.ca.gov/80_BARRe...08-09%20V3.pdf
If you do pass you go through the process again when 2 years are up.
- Curious what you emission thresholds are in California? They are called "cutpoints" and can be looked up here:
http://www.smogcheck.ca.gov/pubwebqu.../ShowMake.aspx
Well, that's enough good news for now. I am going to go try again later this week. And, by the way, the BAR tech said a lot of people are upset that they are not passing.
All for now.
