06-14-2010 | #21 | |
Re: ZR-1 Block Numbers
I guess you may never know until you dig in and look at it. But I would say no if I had to guess.
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1 1989 ZR-1 #58 LT5 only 1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110 NCRS #3,182 SACC #2,420 Member Corvette Museum Corvette Forum: "ewjxn" 2009, 2010 Gathering Attendee |
06-14-2010 | #22 |
As I understood it, the assembly of LT-5 motors had pretty well ended by 91-92. That includes service motors. The date on the hood indicates the car was built in June of 92. That coincides well with the VIN# being 474.
06-14-2010 | #23 |
So does the 1059# that is stamped into the block and the girdle 0f 90 ZR-1 #702 indicate production sequence?
06-14-2010 | #24 |
I don't think so, do you have a picture of the stamps? I have found matching numbers stamped in the heads and cam covers of 1989 #058. They are in the 600s.
06-14-2010 | #25 |
D/sFront of block D/sFront of Girdle
06-14-2010 | #26 |
22 motors were produced each day
1992 Birmel went out of business Last LT-5 was produced on 11/24/93 Hard to say if a 6/17/92 LT-5 would be a 2 or 4......we might be able to find the block # and it would tell us
06-15-2010 | #27 | |
You're probably right about the re-stamps just being a screw up. Just so happened that both plants messed up on the same car! But still seems strange for there to be such a big gap between the block casting date (03/07/90) and the build/priced date (5/22/90), especially since ZR-1's were in high demand at the time. Over 2 and a half months. On the MM stamp, they didn't completely grind out the original number, you can still make out part of the original numbers. I'm pretty sure that the last 4 digits were "2299", which would match the last 4 of the VIN. Interesting mistake for them to make, would mean they knew that this LT5 was going to be for 2299.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
06-15-2010 | #28 |
just drop the pan already..
06-15-2010 | #29 |
Look at the front cover to tell if it is a 4 bolt main engine. Lwr corner, driver side rounded = 375 hp 2 bolt, square = 405 4bolt.
06-15-2010 | #30 | |
good to know though
