06-11-2010 | #1 |
Wheel house body panel screw/bolt
I noticed I have lost one of the screws holding the wheel house to the hood. Anyone know the spec on these and if they're available?
Thanks Dave
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
06-11-2010 | #2 |
Re: Wheel house body panel screw/bolt
There should be a number of them on the upper wheel housing. I think Corvette central carries them. Try CC # 20002 $1.25 each
06-11-2010 | #3 |
Thanks I dont find anything on that CC# though
06-11-2010 | #4 |
COrvette Central sells them in packs of five. They had an Ebay listing for these just a day or so ago. They might not come up under a ZR-1 search. Try "90 - 91 Corvette" -- that will probably get a hit.
Troy Marquis 68 L-89 #9876 - Under Restoration 69 L-88 #21214 - L-88 Tribute 70 L-46 #9516 - Top Flight 71 LT-1 #2638 71 LT-1 #5172 - Canadian Export - Top Flight 71 LS-6 #15133 - Canadian Export - Under Restoration 90 ZR-1 #338 - Restored 90 ZR-1 #890 Project Phoenix 91 ZR-1 #1255 - Triple Crown Winner 69 Firebird Project: w/ 69 L-89 Motor #24390 16 Z06 Admiral Blue/Red Interior (1 of 2) - Sold |
06-11-2010 | #5 |
The closest I seem to be able to find are "TORX BODY SCREW - WITH WASHER - SET OF 5" Part #344032. Are those the ones?
06-12-2010 | #6 |
I'm not 100% sure on this but I think those are the same as the screws that hold the wheel house inner panels in place.
Pull one of each out and do a camparo. Tom
06-12-2010 | #7 |
Check your rear tires (just kidding).
06-12-2010 | #8 |
06-12-2010 | #9 | |
Troy
