Old 05-25-2010   #1
todesengel
Default Where can I get
A pin-out of a 1990 zr-1 engine wiring harness?
TIA
todesengel is offline   Reply With Quote
Old 05-25-2010   #2
65ZR1
Default Re: Where can I get
The factory servive manual ( I think the 90 was a supplement) has all the wiring diagrams and pin outs.
I have a 94 FSM, otherwise I would scan some of the pages for you.
65ZR1 is offline   Reply With Quote
Old 05-25-2010   #3
todesengel
I appreciate it. I have the suplement, but not the wiring supplement (if that is where it is at).
I guess Ill just get out the old multi meter and start tracking it all down.
Old 05-26-2010   #4
I don't have a scanner, and I'm not quite sure which diagrams you need from the 90 FSM, section 6E or the 8A electrical manual....I'm not "with it" on this electrical stuff, totally in the dark with that stuff!
However, if you would like I can go to the local office depot and I'm sure they can make copies of the pages you need and I'll mail them to you...any help?
Old 05-26-2010   #5
FULLPWR
FULLPWR's Avatar
TIA
I have all the manuals for my 90. but they are at home, when I get home today I can scan whatever you need or send you the manual you need.
Unless you have gotten the info. already....let me know..
Luis
FULLPWR is offline   Reply With Quote
Old 05-26-2010   #6
The pinouts should be in the FSM.
Old 05-26-2010   #7
todesengel
Thanks guys. I just need the ecm pin-outs (computer plugs), and which pin is what
I am needing , cam angle sensor, injectors, ign, ait, tps, etc
Old 05-26-2010   #8
gbrtng
gbrtng's Avatar
Pin-outs are only part of the story - you need signal levels and impedances too which will require more study. Holler here for help ...
Old 05-26-2010   #9
todesengel
I appreciate that, but once i get the pin outs, it is all I will need. I have the equipment to monitor and record values from the sensors once the diagram is identified.
There really arent that many sensors, so if I cannot get the pin out I will just track through continuity.
I appreciate the concern though, and the offer for help
Old 05-26-2010   #10
bdw18_123
TIA
Here you go:
