#21 | |
![]() Join Date: Jan 2009
end works great. Run it all the way through and back out like your cleaning a gun barrel.
#22 |
The vacuum lines the first time out were abit scary but Ive pulled the plenum enough I think I could do it without any pictures.........but Ill take some just to be safe.I dont know if you have the plenum back on yet but Haibeck has a DVD for the system checks for the vacuum system as well as the fuel system for leaks.With the DVD you can watch the actuators for operation and pressurize the fuel system to check for leaks.
#23 | |
![]() Join Date: Jun 2009
1994 ZR-1 Admiral blue/beige #67 |
#24 |
Finally found time to finish it up....!!
#25 |
![]() Join Date: Nov 2008
I'd be scared to drive that work of art!
#26 |
![]() Join Date: Dec 2003
Looks great! You're now an accomplished pro!
#27 |
![]() Join Date: Mar 2004
Great job!
#28 |
Thanks for the compliments and also thanks to those on this forum for all the information and help!
#29 |
#30 |
![]() Join Date: Nov 2007
WooHoo!! Thatz beautymuss!!!
![]() ![]() P. |
