Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 04-01-2010   #1
QB93Z
QB93Z's Avatar
Default Replacing Injectors
Last Sunday we replaced the injectors in George's 1990 ZR-1. The car does not have many miles on it and the injectors were original.
The results were the car performed significantly better with new injectors.
When I measured the injector coil resistance of the old coils, I found 4 that had low reisitance.
My measurements were taken at room temperature. Most of the injectors read 12-12.5 ohms. Three of the bad injectors read about 6 ohms.
If you still have original 1990 injectors in your ZR-1, I suggest checking/replacing them.
If it isn't fun, you aren't doing it right!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Last edited by QB93Z; 04-01-2010 at 01:30 PM. Reason: cant type write the furst tyme.
Old 04-01-2010   #2
Default Re: Replacing Injectors
Good to hear. I wonder sometimes how many Zs are out there running on crappy injectors and/or breached vacuum system with owners who are oblivious of the fact.
Old 04-01-2010   #3
ScottZ95ZR1
ScottZ95ZR1's Avatar
I've wondered about this. As far as I know I have no injector problems and I've read the '93-'95 injectors will likely not fail.
But after 15 years (or more) could replacing them produce a noticeable improvement in performance - even though the stock injectors haven't really failed?
I am somewhat confused as to the chances of my injectors failing.
I remember Dave J had one fail on his '94 but after reading this article on Marc's site I felt there would be little chance I'd need to replace mine?
http://www.zr1specialist.com/HAT%20W...eplacement.pdf
Sorry Jim, I know the post was targeting the 90 model but I was just considering this issue when you posted the thread.
ScottZ95ZR1 is offline   Reply With Quote
Old 04-01-2010   #4
Scrrem
Scrrem's Avatar
Guess I better do a measurement on mine. Great....more maitenance to add to my list
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 04-01-2010   #5
ZR1Vette
ZR1Vette's Avatar
There has been document failures of 93-95 injectors and many have replace them and experienced engine improvement.
Dave can chime in on this one...
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 04-01-2010   #6
Jagdpanzer
Jagdpanzer's Avatar
I believe in David's case it was not a coil insulation failure but one stuck open injector.
Old 04-01-2010   #7
ScottZ95ZR1
Thanks for the quick feedback, guys.
I had just done a search on "injectors" and pulled this thread. I didn't look closely at it's location to realize I was jumping into WAZOO-land.
No place I'd rather be given the choice!
Back on topic, it makes sense that a new set could improve performance even without a full-blown failure.
I bought a set from FIC when they had the limited supply of brand new Bosch injectors and was wondering if I'd really ever use them.
They are vacuum sealed but I guess I'll need to have them checked out before I install them if/when that day comes.
Old 04-01-2010   #8
Yes sir! The primary dumped and blew out a cat that got stuck in the X-Pipe....
Thanks for your help that day with the Gears!
Old 04-01-2010   #9
ScottZ95ZR1
Just another reason I wish I lived in WAZOO-land.
Those Viper gears are still sitting on the shelf next to the injectors !
Old 04-01-2010   #10
QB93Z
QB93Z's Avatar
You are always welcome in the Land of WAZOO. Plan a short trip. Come on out. Do some work on your car (we will help!!). And see the sights of the Nation's Capital, Charm City (Baltimore), Gettysburg, and many other neat places. We are pretty good hosts. Just ask Jerry, Scott, Craig, Marc, George, and etc.
