Old 04-01-2010   #1
max76
Default C5 Z06 Brakes Conversion
Hi guys,
a my friend here in italy must sell the C5 Z06 brake kit. front and rear caliper with pad.
So, my question is: May mount this kit on my stock 1990 Zr-1 Wheels???
I need some braket modify?
Someone of you sell the modify braket?
I need to change stock rotors?
Tahnks in advance
Max
max76 is offline   Reply With Quote
Old 04-01-2010   #2
Default Re: C5 Z06 Brakes Conversion
Originally Posted by max76 View Post
Hi guys,
Tahnks in advance
Max
Max,
You can use the fronts, but not the rears. Stock rotors for the rear, C5 rotors for the front. Also need caliper mounting bracket from C5 and adapter. They'll work fine on 17" wheels.
Old 04-01-2010   #3
max76
Thanks xfirez51 for help...i've change idea and i don't buy them...
I think that is best originally...so much modify for me that i leave in Italy!!!
So much parts to buy from the US!!!!
Thanks Again!!!
Max
Old 04-01-2010   #4
Aurora40
Aurora40's Avatar
I've heard from other people they won't clear the spokes on a '90 wheel?
Bob Saveland
Former owner of #2517
Old 04-02-2010   #5
93 ZR1 Barcelona
93 ZR1 Barcelona's Avatar
The C5 Z06 brakes will not clear the 90 & 91-93 turbine wheels.
They will have side interference on the front brakes.
You should upgrade to 94-95 A-Mold wheels.
If you install the C5 rear calipers you will miss parking brake.
93 ZR1 Barcelona is offline   Reply With Quote
