Old 03-04-2010   #41
scholtmj
scholtmj's Avatar
Default Re: Pulled the plenum, now what?
Originally Posted by Jeffvette View Post
Jeal camshafts eh?
End results....
Since Kirchhofer did the work I assume so.
Do all Jeal cams have similar wear characterstics?
scholtmj is offline   Reply With Quote
Old 03-04-2010   #42
Jeffvette
Some more than others. Just find a new set of intake cams, check your lifters for scalloping. And be thankful you caught it in time.
Old 03-06-2010   #43
Jeal camshafts eh?
End results....
I dont know too much about cams................but that looks baaaaaaaaaad.
Old 03-06-2010   #44
Old 03-06-2010   #45
Pete
Pete's Avatar
You can regrind a set of stock intakes to the same specs as the Jeals if you like them.
We know stock regrinds work.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-06-2010   #46
I have a set of stock cams, if needed.
Old 03-06-2010   #47
scholtmj
scholtmj's Avatar
I feel this is going to turn into "while I'm there".....
Stock re-grinds would be considered stage 1? The Jeal lobe must be outdated by now.
Old 03-07-2010   #48
tpepmeie
The Jeal billets I had tested were soft as butter just beneath the surface. In the 30 rockwell range. The heat treatment just wasn't done correctly it appears, and the top hard layer is very very thin. Stock lifters are 62 or so.
Its a shame, really. I *thought* they used Piper Cams at one time, whom I would expect better from. Cant say for sure if these (or the EA22's) are from Piper.
