Old 02-25-2006   #1
Chris
Default Slowww cranking...need battery recommendation
Went out to the garage to fire up the Z and it turned ever soooo slow, finally click...click...click...click. Okay time for a new battery. Any suggestion on brand? I don't care about the weight or cost, looking for something dependable.
Does brand really matter? What are others using? Any gel cells other than optima?
Chris is offline   Reply With Quote
Old 02-25-2006   #2
Default Re: Slowww cranking...need battery recommendation
75-7YR BATTERY, PROFESSIONAL - 7 YR BCI 75 CCA 0690 32 VALVE SIDE TERMINAL
Hey Chris,
I use and love AC Delco and saw a lot of recommendations for it when researching mine. But I have also heard good things about Interstate with 700 CCA. You can't go wrong with Delco, but I think there are many other good batteries out there as long as you stay name brand. I stay away from any that requires cutting the top posts off as I experience when almost buying the Napa Gel. Optima is supposed to making a direct application battery for the C4 but I think they still have the cutoff post issue or other have found resolution to the interference with the cruise control but bending brackets, etc. I'm a direct fit person with correct application from manufacturer. From my own experience, I would not recommend Sears Die Hard though.
http://www.ibsa.com/estore/view_prod...J9DC7&js=1Part
# MTP-75 (Mega-Tron Plus - 85 Months - 700 CCA)
Old 02-25-2006   #3
Z Factor
Z Factor's Avatar
http://www.zr1netregistry.com/forum/...ead.php?t=1351
Old 03-02-2006   #4
N8nSM
N8nSM's Avatar
I've always had awesome experience with the Optima batteries. I've never killed one yet and I have a lot of stereo equipment in my Tahoe.
I like the yellow tops but if you aren't pushing huge subwoofers or amps the red top is probably more than adequate.
-Nate
[FONT=Tahoma][COLOR=blue][B]Nate[/B][/COLOR][/FONT]
[FONT=Tahoma][COLOR=blue][B]Santa Maria, CA[/B][/COLOR][/FONT]
[FONT=Tahoma][COLOR=blue][B]1990 ZR-1 #224[/B][/COLOR][/FONT]
N8nSM is offline   Reply With Quote
Old 03-02-2006   #5
Chris
What sorta modification do you have to do to the optima?
Old 03-02-2006   #6
N8nSM
N8nSM's Avatar
I have a Die Hard in the ZR-1, the Optimas are in my Z28, Tahoe, IROC, and Silverado. The yellow top in my Z28 has been reloacted to the rear spare tire well. The 4th Gen Camaro's have a pretty decent sized area and BMR makes a bracket that bolts right in once you remove the spare tire.
All the others the Optima fits right in the stock location with out any problem. I was going to buy an Optima for the ZR-1 as well but I was able to score the Die Hard pretty cheap and I didn't have to wait for it to be shipped.
-Nate
Old 03-04-2006   #7
Chris
After some research decide to go with the Exide. IMO I couldn't justify paying the premium for AC delco when they have some problems leaking.
Old 03-04-2006   #8
Z Factor
Z Factor's Avatar
What are the CCA's?
Old 03-04-2006   #9
Chris
Originally Posted by Z Factor
What are the CCA's?
A whopping 630 cca 800 ca. (Went with what was close to the house and readily available to purchase. The price was $64 with tax. The Delco battery was $105 plus tax.)
