Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Prototypes (pre-production)
Old 02-18-2010   #311
1989ZR1#74
Default Re: 1989 ZR-1 Pilot #004 Thread
Ok started on the last wheel well.
Before:
Found some marks on the pass side half shaft:
1989ZR1#74 is offline   Reply With Quote
Old 02-18-2010   #312
did you ever find out why everything was painted black?
Old 02-18-2010   #313
bdw18_123
It was probably so that the all the stuff in the wheelwells and under the car would not be visible in the photos, since Eric's car was originally purchased by the advertising division of GM.
Old 02-18-2010   #314
Hammer
Hammer's Avatar
Talking Re: 1989 ZR-1 Pilot #004 Thread
Eric,
That is a lot of work, I know, I've done it to mine. Seriously, get some of Adam's Invisible undercarriage spray for those now. You will be surprised at how much it helps.
Keep the posts coming, I love this.
Thanks a lot.
Old 02-18-2010   #315
TommyL
Originally Posted by Hammer View Post
Eric,
Thanks a lot.
In for a nickle in for a dime...instead of covering everything with a spray ect. might as well take it apart to detail and touch everything up. It is far easier to clean and detail, takes less time, does a more thorough job and it is only nuts and bolts...the odd screw.
TommyL is offline   Reply With Quote
Old 02-18-2010   #316
1989ZR1#74
good tip, This one unfotunately will not get driven much and AZ is very dry so it should stay pretty clean. I originally thought that the blackout was for pictures, but I since learned that the VOCO school painted it. It appears to have at least 2 resprays. Bright red, then the metallic blue. Whoever painted it red did not mask the wheel wells. There was a lot or overspray. Their solution was to cover the red with black. Then it was painted blue. There is some (not as much as the red) blue overspray. This was also covered with another coat of black. When I remove the black there is a layer of black, some blue, another layer of black then some red then the natural finish. The trick is remove the four coats but not the fifth. Luckily I have done this a few times before. mechanical removal is always first, Putty knife/soft wire brush, then use removers. I pressure wash the parts that can be removed (wheel tubs and inner fenders) then repeat. I will keep posting until I stop forward progress. Hopefully that will not be for a long time.
Old 02-18-2010   #317
Blue Flame Restorations
You can show off your detailing skills in BG this year. It's really beginning to clean up nicely. Can't wait to see it in person.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-18-2010   #318
Eric,
you wanna clean mine next? I still have Colorado Dust underneath it from when I bought it in 2007
Old 02-19-2010   #319
1989ZR1#74
Eric,
Sure, but you have to bring it to me... With both Keys! Every wheel well detail requires a 500 mile test, leak evaluation drive. In order to determine what type of cleaning solutions need for the rear half shafts both sets of injectors must be engaged.
Old 02-19-2010   #320
Sure I will bring you the door key and ignition key
Wow.. 500 miles for each wheel well, that (unfortunately) is more mile then I put on it last year
