Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Northwest Region
Old 09-24-2009   #11
MikeG
MikeG's Avatar
Default Re: Trip Preparation
A lot of things could go wrong on a long trip, but I just took #135 ('91 with 70+K miles) on a 5K+adventure - SD to TX to WA, then back home to SD. The only trouble I had was the oil pressure switch leaking. Once it was replaced the only other problem was having to refuel the Beast ever so often! Oh yeah, I forgot, locked my keys in the car in Yellowstone. Having good AAA coverage is a good thing to have!
MikeG is offline   Reply With Quote
Old 02-01-2010   #12
WydGlydJim
WydGlydJim's Avatar
Couple of those red shop rags. Wrap them around the can of Fix a flat. Make sure you change out the wiper blades before the trip. Maybe a few fuses and common bulbs?
I went to get some refills the other day, and believe it or not, not a soul in Wichita sells em........only the whole blade.......uhggg! Anyone got a tip on a source?
2009 LS9
1990 LT-5/sold/Bought my Baby back
1994 Lingenfelter LT-5/sold
1973 LS4/sold
WydGlydJim is offline   Reply With Quote
Old 02-01-2010   #13
Originally Posted by Jeffvette View Post
Rick short list.
Cash for the hookers
Best advice I have heard yet!
ps Kevin that was excellent advice with the insurance....
Old 02-01-2010   #14
QB93Z
QB93Z's Avatar
I use ExactFit by Trico. 20-2 is on the package. I get them at AdvanceAuto and Auto Zone here on the East coast.
Giood Luck.
Old 02-17-2010   #15
For the drive I'm packing an alternator water pump, some plenum gaskets, and a couple of serp belts. Plus these items don't take a lot of room in the car.
If you are in a pack of Zs.....and you are the parts guy...yes to this list. I used to carry water pump, alternator, hoses, belts, and even gaskets. I found that I never used them including the fluids I took along
I do carry a volt/ohm meter as well as a couple screw drivers (flat and philips), metric allen and torx set. I also carry a metric socket set and flex metric ratchet set.
The tools are a bit overdone but I may use them on someone elses car that has had poor maintenance or poor trip preparation. I also carry a good flashlight or even two flashlights. Yes....a credit card with high limit and good cell phone with Jeff's number.
I concur with Daryll
