If someone has the under plenum connector part numbers for the ignition module (3 way next to the long horizontal one at the back of the module) and the large 3 way that goes in vertically into the front of the module, and the secondary vac solenoid (white 2 way), i'd really be grateful. The tabs broke on me.
![]() Join Date: Dec 2004
I don't know the part numbers, sorry. Maybe this site could be of some help;
http://www.rs-autosport.net/catalog/...roducts_id=192 Or perhaps this one; http://www.rowand.net/Shop/Tech/Auto...Connectors.htm ![]()
These are the 4 items under the plenum.
USD $27.24 1210185 ![]() USD $43.76 12117339 USD $46.06 12167116 USD $50.30 12102776 |
![]() Join Date: Aug 2006
I can't remember all of them but one that connects to front of the ignition module, I swear, is a three prong weather pack (male).
Ignition module connector on mine looks completely different from pics from Kurt.
Can someone post the pic for me? Somehow I cannot connect to my photobucket. Could it be that 93up have a different connectors? Mine is a 94. |
http://i658.photobucket.com/albums/u.../Connector.jpg
This is the connector I had to replace for the ignition module. Perhaps it's early year vs. later year difference... ![]() |
#7 | |
That connector has a couple of places. TPS sensor, MAP sensor, and O2 sensors. |
On my 94 this same connector, slightly modified (razor cut parallel to the prong to duplicate busted one), fit perfect on one of front ignition module.
$5 at auto part store. Chevy dealer price was around $15 and would require wire splice. Guess which route I took. Yes, it's identical to TPS connector. |
O.K! Now it comes back to me! My original factory connector was a 3 tubular prong weather pack with sort of rectangular plastic box with 3 round holes to receive weather pack. Then the whole combination (resulting in final configuration similar to what limey is showing) sliding into ign module.
![]() Looking at Jim's pic on another post helped me recall. |
#10 | |
http://www.weatherpack.com/ |
