Old 11-23-2009   #71
ZR1Vette
ZR1Vette's Avatar
Default Re: Can I get a lift?
Was anyone else nervous after they installed their lift? Unfortunately, I am out an inch away from being able to move up to the next safety latch, right now I am only clearing the bottom car by 3 inches. I may look into a different garage rail.
I have been out to check the safety locks about 20 times....
Glad to see you got it installed Your comment suggests that you are supporting the upper Z by the cables (which are rated at 14K lbs each) and not with the locks...yea that would concern me a bit... can you adjust the lock rails upward so that the next lock slot would be in position to have the lock work? If not you could just place a 2x4 'post' in each column snug to the cross rails...not optimum but at least some additional safety factor.
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 11-23-2009   #72
Toyvet1
Lee just re-adjust the rails the the safety locks catch on. You should have some adjustment up or down with the adjustment nut. I think mine lift had about 6 inchs of thread . The ram will leakdown until the lift finds the safety latch over time.
Old 11-23-2009   #73
QB93Z
QB93Z's Avatar
Lee,
Do you have a standard garage door opener on the door where your lift is like the one on the right in the pic below?
If so, you can gain some overhead height by changing to a jackshaft opener by Lift Master and adding the rail extensions.
I was even able to remove one of the door panels that were required to use the standard screw-drive opener.
In this picture you can see the opener motor. It is the black mechanism attached to the door counter-balance spring rod:
Old 11-23-2009   #74
Pete
Pete's Avatar
Jim,you also got my interest.
Where did you get that screw drive opener and does it have a remote.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-23-2009   #75
Jim, my issue is not the drive, its the door height.....by the way can you come over and put my compressor up in the air like that
Old 11-23-2009   #76
96LT4
I bought a Superior lift a few years back through the GS Registry. Nice thing is that it came with casters so I can move it anywhere in the basement. Drip pans are a must too!
1969 Camaro RS/SS Convertible, 427 4 speed
1996 LT4 convertible red/black/black
1996 LT4 convertible yellow/black/black
1995 ZR-1 white on red
96LT4 is offline   Reply With Quote
Old 11-23-2009   #77
Pete
Pete,
I have a good friend who installs garage doors and openers. If you want I can ask him.
Old 11-23-2009   #78
QB93Z
QB93Z's Avatar
Pete
Hey Pete,
Here is a WebSite that shows the opener I bought.
http://www.prodoorparts.com/products/167.cfm
It is a very nice setup. I got a button for inside the garage, a keypad for outside the garage and a mini remote to keep in the car (which has a better range that the Genie). There system does not integrate with the Genie or Sears systems but no big deal. It comes with an overhead light.
Install is a little more involved that a screw drive opener, but it was not a problem.
Phil (Jagdpanzer) clued me in on this opener.
Old 11-23-2009   #79
QB93Z
QB93Z's Avatar
No problem, I'll bring my son. Without his help to lift it, I would still be walking around it.
I know what you mean about the door. Can you gain any height by adding the track extensions? What happened to me was even after I raised the door as high as I could, the L-shaped bracket that sticks down from a screw drive opener "took away" about 8 inches of usable space.
Old 11-23-2009   #80
Kb7tif
So now what? How do they handle earth quakes?
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
