Old 11-08-2009   #1
Default More on Z06 Wheels
Had a chance today to go over to my friend Pete (not ZR-1) and try on his OEM Z06 wheels from his 2007 car. He has a silver Z.
Here's the album. Comments please.
Old 11-08-2009   #2
Default Re: More on Z06 Wheels
You shouda bolted azz with those and not come back.
Nice!
Old 11-08-2009   #3
looks good, if you go that route, you need to lower the car a bit to make it look perfect
Old 11-08-2009   #4
jonszr1
jonszr1's Avatar
darn ,dom those look great . they if they were polished or chromed would look almost like the ccw wheel a guy had on his blue zr1 a while back . what size are they?
Old 11-08-2009   #5
Ccmano
Ccmano's Avatar
Looks fantastic, gives the car a more up to date look. Needs lowered.
I may have to do that when I'm employed again.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 11-08-2009   #6
flyin ryan
flyin ryan's Avatar
Uummm...not sure . I mean I like the wheels, always have but on the Zee, tires kinda look like rubber bands in some pics, as stated on here maybe lowering would help that look out a bit . I'm not much help. Like the color of your car, BTW .
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 11-08-2009   #7
Brad,
Those are 18x9.5/19x12. With a .5" spacer I think the rears would line up nicely and everything clears. Even with no spacer the only issue is a brake line that could easily be modified. The fronts are 40mm offset but there's a ton of clearance. The tires stick out ever so slightly. Almost a non issue IMO.
If this could work out, then it opens up the availablility of buying all those OEM wheels and tires the C6 crowd is selling.
Any comments on CompGrey color?
Old 11-08-2009   #8
Jeffvette
I still think the best bet is to get an aftermarket front wheel and the use the back factory wheel with a spacer.
http://www.zr1netregistry.com/forum/...ead.php?t=2337
Old 11-08-2009   #9
Jeff,
Logically speaking I agree with you, however, aesthetically, the difference is nearly a non issue. I would buy a good set of OEM wheels, possibly tires with them, use a 1/2" spacer on the rears, then go on my merry way. Bob's car is clearly "slammed" while mine clearly is not. I would look to lower mine by about .5-.75"
Old 11-09-2009   #10
Jeffvette
True, that is one problem with going to bigger wheels when you are slammed. I just think it looks funky out of the fender lines, plus the extra debris kicked up will chew up the lower panels.
