Old 10-24-2009   #1
rhipsher
rhipsher's Avatar
Default Headed to Lonstar drag strip
For street wars. I want to see how the car does since the top end porting and 13.5lb Fidanza flywheel has been done. Time to dust the helmet off and do some ground pounding.
Old 10-24-2009   #2
jonszr1
jonszr1's Avatar
Default Re: Headed to Lonstar drag strip
fave fun big guy , remember with the light flywheel you need to raise the launch rpms to about 3500. anyone going to do vids for you ?????
Old 10-24-2009   #3
rhipsher
rhipsher's Avatar
I'm gonna try to get some friends to video it for me. Talk is cheep. You need video and time slips to back yourself up. The only thing I'm going to do to the car today in preparation is put a new fuel filter in since the car has been sitting for 6 months. Then just lower the rear tire pressure to 25 psi.
Old 10-24-2009   #4
Have fun!
I hope you come back with a very baaad case of permagrin!
Old 10-24-2009   #5
Jagdpanzer
Jagdpanzer's Avatar
Don't be afraid to go lower if you have problems hooking up all those newly awaken horses.
Best of luck and do the ZR-1s proud.
Old 10-24-2009   #6
jonszr1
jonszr1's Avatar
rick, hope you get this before you go .since your on street tires, you might really consider short shifting first to second around 5500-6000 . if you go to red line your liable to really spin the tires on that gear change . you can go as low as 20 lbs on the rear tires .
