Old 10-08-2009   #1
Default A missing nut
Hi all,
I am missing a black nut, possibly 4mm?, that holds aluminum shield/trim over the throttle pulley.
Does anyone have a spare I could buy?
Thanks.
Old 10-08-2009   #2
bdw18_123
Default Re: A missing nut
Funny, I need those too, plus the screw that attaches it to the airhorn.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 10-08-2009   #3
Jagdpanzer
Jagdpanzer's Avatar
I was also missing one of these nuts but luckily found it stuck in the inlet of engine valley drain tube when titivating under the plenum last year. I can't tell you how surprised and gratified I was when I discovered it was the missing nut as I had been searching for one to no avail since I first bought car. When I first looked in the valley after removing the starter I said to myself damn what a skimpy drain hole they put in here however, after poking around on it a bit with a pointed mettle scribe to help it drain better out popped the missing nut. And boy was I relieved that drain tube turned out to be much larger than it first appeared.
May you also have similar luck in you hunt
Old 10-08-2009   #4
No, Phil. I don't want to pull the freaking plenum again for a while!!!
Thanks for the well wish though.
Old 10-08-2009   #5
Hi all,
Thanks.
I don't think I have it but I can look..
Old 10-12-2009   #6
QB93Z
QB93Z's Avatar
I discovered that I need one of these nuts also. If you find a source, please let me know.
If it isn't fun, you aren't doing it right!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 10-12-2009   #7
I know I 'had' two.. but cannot find them at the moment..
Old 10-12-2009   #8
VetteMed
Married?
Old 10-12-2009   #9
Originally Posted by VetteMed View Post
Married?
no I HAVE those..
Old 10-12-2009   #10
bdw18_123
no I HAVE those..
1993 Corvette Coupe
