Old 10-04-2009   #11
Default Re: What are you using to install harmonic balancer/torsional damper?
Originally Posted by carter200 View Post
Ok, Dad had a mini stroke yesterday but is fine. On blood thinners and blood slickers. I'll be back to the shop tomorrow.
Sorry to hear about your Dad and I hope all goes well with recovery and treatment. I sent you an email.
Old 10-05-2009   #12
flyin ryan
flyin ryan's Avatar
Originally Posted by Jeffvette View Post
Kent Moore tool. It's a 1.0 thread bitch.
Where'd you get that from...
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y.
Old 10-05-2009   #13
Prayers offered for your Dad. I hope everything turns out okay.
Old 10-05-2009   #14
carter200
carter200's Avatar
Tom,
Thanks for the kind thoughts.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 10-10-2009   #15
Running into a brick wall with anyone that makes a M16 X 1.0 bolt in approximately 6" length that I think could work with a large washer and nut. All negative results with all the big bolt manufacturers, but I have one quote waiting for a response from these guys: http://www.tacomascrew.com/products
If it works I'll post here.
Old 10-12-2009   #16
65ZR1
Can you get a shorter one? If so, send the bolt to me and I will machine a thread on the other end that will screw into the balancer tool. Just let me know what thread you need.
65ZR1 is offline   Reply With Quote
Old 10-12-2009   #17
Jagdpanzer
Jagdpanzer's Avatar
I'm sure your local machine shop could whip this out very easily. Or you can buy a M16 x 1.0 die and with some 5/8" round stock (close enough to 16 mm) and make your own.
http://metalworking.mscdirect.com/CG...PMPXNO=1725246
Old 10-12-2009   #18
Thanks for the offer and I'll see what else is out there. I like your idea you suggested at first and it might be the way to go. I'll check around and let you know. The Blue Point kit that I had from Snap On included these: Description:
Includes seven adaptors for use on a wide range of engines. Adaptor sizes are 7/16"-20, 1/2"-20, 9/16"-18, 3/4"-16, M12 x 1.5, M14 x 1.5, and M16 x 2.0.
Old 10-12-2009   #19
I'm sure your local machine shop come whip this out very easily. Or you can buy a M16 x 1.0 die and with some 5/8" round stock (close enough to 16 mm) and make your own.
Thanks, I'll see what can be done here. I definitely won't try it myself, but like you said a good machine shop should be able to make this.
Old 10-16-2009   #20
billybaloneey
billybaloneey's Avatar
Any updates on a tool to install your balancer? I will have to be worrying about it in a little while.
Clint aka billybaloneey
'94 - C4 ZR-1 #445 - Black/Black
'05 - C6 silver/black 6sp
'85 - C4 white/graphite (almost done) automatic
'78 - C3 silver/black (a work in progress) automatic
billybaloneey is offline   Reply With Quote
