Old 09-30-2009   #11
Default Re: Headers Installed
I have a set of Watson 2" going on the 90.....should be interesting. Too many projects to get these on right now.
Old 09-30-2009   #12
So many Z's so little time
Old 10-02-2009   #13
npritchard777
Does anyone know of a set that is CARB certified/approved?
Damn CA SMOG Nazi's...
-Nate
npritchard777 is offline   Reply With Quote
Old 10-02-2009   #14
Pete
Pete's Avatar
-Nate
Watson's had all the smog stuff but are NLA.
Call Stainless Works see if they can make a set with the AIR tubes.
Other choice would be cut off stock AIR tubes and have them welded on headers.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-02-2009   #15
Kb7tif
Well these had all the smog stuff, but it was all welded shut and ground off then they were ceramic coated. I love these things, and no lt-5 should be without headers.
Before I put these on and the fidanza, the lt5 was kind of boring after having the lt1 and lt4. the 2 mods completely transformed this car. This is a very powerful engine.
Old 10-03-2009   #16
Thumbs up Re: Headers Installed
Yes...Yes they are. Your next forray should be to P&P the top end.
(I damn near swallowed my teeth, first time I whacked the throttle last spring! I have to feather the throttle in first, and it squirms like a snake in second now!)
Gawd, I love these engines! Soooo MUCH return for relatively simple DIY mods!
Old 10-03-2009   #17
ittlfly
-Nate
There are NO long tube headers made for any smog compliant vehicle that are legal in California. The only way around it is to stuff the LT-5 into a 1972 or earlier car...... At least for the moment. Who knows what those bastards in Sacramento will try next. damn SOB's!
ittlfly is offline   Reply With Quote
Old 10-03-2009   #18
Jeffvette
Pete
Doesn't matter if they have all the fittings. They do not have a CARB approved number on them.
Old 10-03-2009   #19
How does CA or other states account for the need to replace Cats? No replacements, so there has to be a rule or way to address this. Is there not an exemption..all else fails get a damn PO Box in IA, SD or some place.
Old 10-03-2009   #20
Pete
Pete's Avatar
I figure if it passes emissions then your good to go.
A visual is a whole other story.
In IL if it passed there was no visual.
I thought the same for CA.
In IL they did away with OBD I emissions
When IL had emmisions for OBD I there were ways around it like show car, basicly insure it as a show car limited miles (3K year)
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
