Old 09-08-2009   #1
Kb7tif
Default Header install
Just a note if by some chance you are hesitant of a DIYS install, Its not bad, Fun actually, I got my pass side manifold off in about 2 hrs. Im not done yet but it looks pretty positive.
Well I got the drivers side off little more of a PITA but its not bad. 2 1/2 hrs.
Hints, Heat shields of the passenger side stay on. Dont waste time loosening. Drivers side heat shield screws need to come out (PITA) shields can stay on. Unbolt engine and lift about 1 1/2 inch, I Kept exhaust connected until that side was unbolted, kept everything from binding.. Most stock manifold bolts both sides are removed from the side. Easy Money. Dont rush get pissed- drop it for the day.
Wait untill you see the choke points on the stock manifolds.
Time saving tools- 8mm flexhead stubby, long 15mm offset boxend, 10mm long flexhead. 10mm and 8mm
swivel sockets. Thats really about it, Just 3/8 general ratchet stuff.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 09-08-2009   #2
Default Re: Header install
no pics?
Old 09-08-2009   #3
Did you pull the inner fenders? Makes life easier
Old 09-08-2009   #4
Kb7tif
No pics, used all the information people have posted in the past installs, saved alot of effort!
1992-Zr-1 Sold.
Watson Headers
Random tech cats
Fidanza Flywheel
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 09-08-2009   #5
what are the torque specs on the bolts
Old 09-09-2009   #6
Tight
Old 09-09-2009   #7
I cannot find "tight" on my torque wrench.
Old 09-09-2009   #8
Jeffvette
Good luck getting a torque wrench up there.
Old 09-09-2009   #9
Jeffvette
You did the easy side first.
Old 09-09-2009   #10
Well if he did that would be the tight setting he was looking for
