Old 08-31-2009   #1
Default Left side Coolant fan issue
I was working on the windows on my Z this weekend. After a couple minutes the fan came on.. thing is the car has not been started for a couple days so I know the temp did not require it. Not sure what it could be but looking for some suggestions
Old 08-31-2009   #2
65ZR1
Default Re: Left side Coolant fan issue
Check for codes. If you went in to limp home mode the fans come on.
65ZR1 is offline   Reply With Quote
Old 08-31-2009   #3
No codes.. start the engine and the SES is off..
shut off engine then turn key to on, with engine not running fan stays off.
I need to go through the troubleshoot guide in the manual
which fan is the left? 1 or 2?
Old 08-31-2009   #4
Pete
Pete's Avatar
Jeff, just one fan goes on or both?
If it goes on with with key on i'm thinking relay.
Swap out relays.
Check Prom.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-31-2009   #5
Swap out relays.
Check Prom.
Pete
Will do, and yes only one.
Old 08-31-2009   #6
If you ever want to come over and swap parts out of one of mine to test, let me know. Might save you some $
Old 08-31-2009   #7
Thanks Lee.. If it gets to that I will
need to troubleshoot it first
Old 08-31-2009   #8
Relay?
Old 09-01-2009   #9
Not the Relay, Swapped and the same issue
I hooked up my Laptop, AC Request is set to 'Yes' even when the controller is 'OFF' Keep in mind I have C60 (Manual AC)
So I followed the troubleshooting guide, and it says if I put a test light from Green connector pin #2 of the ECM to ground, I should get a light in Bi-level, AC, Max and Defrost.. it never lights. I need to check the wire and check the under dash connector, but the odd thing is the AC works.. so I am a bit confused on that.. I am guessing I have a loose connection or broken wire Ah well, I will check it when I start working on the passenger side window
