Old 01-05-2006   #1
RiceEatingZR1
RiceEatingZR1's Avatar
Default Clutches?
It seems that I might have to replace my clutch, it seems that when I push the Peddle to the floor its not disengaging all the way making it harder to put in gear also I have noticed that if the car is on a Flat area of road and I put the Clutch to the floor with the car in gear it will still want to Roll forward. I guess my question is I was looking at www.carolinaclutch.com and found a kit but I’m not sure if everything I will need is in that kit the Kit number is: 04-114 does anyone know if I will need anything in addition? Or what I might find I will need?
Thanks
-Shaun
1991 Charcoal Metallic ZR1 #730
[URL="http://www.cardomain.com/ride/2649606"]http://www.cardomain.com/ride/2649606[/URL]
[URL="http://community.webshots.com/user/shaun91zr1"][/URL]
[IMG]http://img.photobucket.com/albums/v211/RiceEatingZR1/Forum%20Sig/Sig1.gif[/IMG]
RiceEatingZR1 is offline   Reply With Quote
Old 01-05-2006   #2
FASTZR1
Default Re: Clutches?
Talk to Tom at Carolina Clutch. He knows the ZR1 setup. My stock clutch did great. My stage 2 clutch and Fidanza flywheel setup from him is not as enjoyable as I had hoped. It engages near the top instead of near the floor like the stock clutch does. May take it out this spring and then call Tom for a stock set up again.
JohnnyB
FASTZR1
91 #233
FASTZR1 is offline   Reply With Quote
Old 01-05-2006   #3
RiceEatingZR1
Thanks Johnny! Ill give him a call.
-Shaun
