08-26-2009 | #1 |
Tech 1A
Hey guys...I wanted to pick up a Tech 1A off that auction site some time. However, they are usually advertised with a lot of accessories. My questions is: what exact cartridges are REQUIRED to make it work on my 94? Never owning one makes it very confusing.
Thanks
1994 ZR-1 # 0102...SOLD |
08-26-2009 | #2 | |
Re: Tech 1A
The ABS system The ECM system The Body System/ Chasis EEPROM These are going off memory but there are a lot of cables and adaptors you will need at well
08-26-2009 | #3 |
Re: Tech 1A
The cartridges are identified like this: "GM 81-92 ECM CARTRIDGE"; "GM 88-92 BODY SYSTEMS CARTRIDGE", etc. You should get cartridges that cover your car. You should also get a manual for each cartridge. My car is a 1990 so the above cartridges cover mine. You also need a vehicle adaptor that fits your ALDL. Mine is a 12 pin. The Tech 1A should come with a power cord that plugs into the cig lighter, and a 14 pin cord. It also may come with a self test adaptor and/or auxillary instrumentation cables such as a "Multimeter test lead".
I still need a "GM88-92 BRAKE" cartridge pn: TK03030B if anyone happens to have one.
JB 1990 #148 Red/Saddle Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice :cheers: |
08-26-2009 | #4 |
Re: Tech 1A
Thanks much for the information. I'd sure like to pick up one of these things as it would make following the flow charts in the FSM a lot easier.
08-26-2009 | #5 |
Re: Tech 1A
I just picked up a tech 1 off a guy on craigslist and it came with a ton of cartriges, only One I have used yet is the mass storage one.
Thing showed me when I turn off my # 6 injector the motor runs the same when I turn off the others the motor starts to bog down so I have a dead cylinder at the moment! this thing confirmend what I had already though was my problem cylinder but its sweet!
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
08-27-2009 | #6 | |
Re: Tech 1A
08-27-2009 | #7 |
Re: Tech 1A
Johnny is there a procedure to delete the old data on the mass storage cartridges? I have a lot of those little buggers.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 08-28-2009 at 05:16 PM. |
08-28-2009 | #8 |
Re: Tech 1A
Does the tech 1A do anything that my AutoXray 6000 won't?
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
08-28-2009 | #9 |
Re: Tech 1A
Yes If you want to know PM me
