![]() Join Date: Jul 2004
Update I will be able to deliver up in carlisle so lets go people!
Ok before I hit the bay with these Ill give you guys a shot at them since it will probably be you buying them anyway! No need to line ebays pockets we already have to deal with paypal. Bellhousings I have 2 of them $300 each http://i150.photobucket.com/albums/s...s/IMG_1170.jpg Throttle body good for a 63MM or larger had some damage by bubba needs finished machining done still stock bore. $250 http://i150.photobucket.com/albums/s...s/IMG_1163.jpg http://i150.photobucket.com/albums/s...s/IMG_1161.jpg http://i150.photobucket.com/albums/s...s/IMG_1162.jpg The airfilter to throttle body accordian air duct $80 http://i150.photobucket.com/albums/s...s/IMG_1125.jpg The ECM cover $75 SOLD Tail light wiring harness $100 http://i150.photobucket.com/albums/s...ghtharness.jpg A/C hard line from evaporator $125 http://i150.photobucket.com/albums/s...or14104967.jpg Interior harness runs from dash to rear of car for lights hatch control among other things $ 100 http://i150.photobucket.com/albums/s...orharness2.jpg FX3 and ABS harness one conector was damaged wiries good $50 http://i150.photobucket.com/albums/s...bsharness1.jpg antenna cable from radio to antenna $35 http://i150.photobucket.com/albums/s...ttenacable.jpg Seat wiring harness for power seats $35 http://i150.photobucket.com/albums/s...sportseats.jpg Low tire pressure reciever $50 I have 2 http://i150.photobucket.com/albums/s...Sreciever2.jpg low tire pressure sensors I have 2 left from this set green and orange $130 each http://i150.photobucket.com/albums/s...arts/LTPWS.jpg A/C line from accumulator $100 http://i150.photobucket.com/albums/s...or10157992.jpg Engine harness pretty sure its from a 91 cut up and for parts only! SOLD 6 speed shifter console with door I have 3 of them they are not perfect they have scrathes and dings they are used. $75 each http://i150.photobucket.com/albums/s...rconsole-2.jpg Rear bumber support brackets I have 2 sets these are on the outboard corners of the LT5 bumper to hold up that ***! $100 a set http://i150.photobucket.com/albums/s...s/IMG_1364.jpg Front wheel well rear splash guards these are ZR-1 specific $75 each http://i150.photobucket.com/albums/s...s/IMG_1368.jpg Door panels black need the carpet replaced cat got to them $100 for the pair comes with new ACC carpet. http://i150.photobucket.com/albums/s...s/IMG_1346.jpg http://i150.photobucket.com/albums/s...s/IMG_1347.jpg dash pad with black carpet $100 (I can get a better pic let me know) http://i150.photobucket.com/albums/s...s/IMG_1344.jpg number of springs valves and keepers I would have to count them all but Im sure some keepers are missing but 8 intake valves $200 for whats in the box http://i150.photobucket.com/albums/s...s/IMG_1338.jpg Exhaust hangers brand new! $ 75 for all three SOLD Fuel delivery and return lines $250 http://i150.photobucket.com/albums/s...s/IMG_1443.jpg O2 sensor extentions for use with headers $100 SOLD ECM mount braket sits behind brake booster $100 http://i150.photobucket.com/albums/s...s/IMG_1451.jpg rear storage compartment doors $35 http://i150.photobucket.com/albums/s...s/IMG_1456.jpg headlights $100 each I have 4 http://i150.photobucket.com/albums/s...s/IMG_1435.jpg headlight covers $40 each http://i150.photobucket.com/albums/s...s/IMG_1428.jpg http://i150.photobucket.com/albums/s...s/IMG_1429.jpg ZR-1 rack and pinion less rag joint $150 http://i150.photobucket.com/albums/s...s/IMG_1459.jpg Rear end suspension pieces, not including the spring brake rotors and the sway bar just the other parts $400 http://i150.photobucket.com/albums/s...e/DSC00163.jpg rear toe/tie whatever bar I have 3 of them $100 each http://i150.photobucket.com/albums/s...age/toerod.jpg ZR-1 brakes probably need a rebuild been sitting for years $200 http://i150.photobucket.com/albums/s...s/IMG_1458.jpg 1991 airbag controler suppost to be good I really don't know? I have 2 if these $50 http://i150.photobucket.com/albums/s...s/IMG_1461.jpg ACC carpet peices $65 for the door sills $45 for the others http://i150.photobucket.com/albums/s...s/IMG_1463.jpg http://i150.photobucket.com/albums/s...s/IMG_1465.jpg Front frame bracket for wreck damage $55 http://i150.photobucket.com/albums/s...s/IMG_1343.jpg Radiator upper and lower supports $75 for upper $65 for lower. http://i150.photobucket.com/albums/s...s/IMG_1361.jpg ZR-1 specific rocker panels $350 http://i150.photobucket.com/albums/s...9/IMG_1625.jpg Pressure plate not sure if its for a L98 or a ZR-1 have to measure it but I think its the smaller one for a L98 $65 http://i150.photobucket.com/albums/s...9/IMG_1623.jpg http://i150.photobucket.com/albums/s...9/IMG_1621.jpg http://i150.photobucket.com/albums/s...9/IMG_1622.jpg 1990 ZR-1 Dash board plastic skeleton and wiring harnes airbag went off so I think the controler is no good and the CCM is seperate $450 CCM has less than 20K miles on it $200 http://i150.photobucket.com/albums/s...9/IMG_1629.jpg Power seat tracks I have 5 of them 2 of them are from a 88 so they have the extra spring all of them work I tested them in my car. $100 each http://i150.photobucket.com/albums/s...9/IMG_1631.jpg Ill be back with pictures of the following later Left and right timing chain tensioners 2 sets expanded $250 each pair. camshaft sprockets viners and camshaft retainers $350 for all of it. 1991 LT5 engine requires assembly torn apart must be checked and rebuild comes with new crankshaft bearings, conecting rod bearings and head gaskets. Includes all accesories plenum and throttle body just not all in the photo will need injectors and harness $5000 ![]()
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 09-01-2009 at 02:58 PM. |
![]() Join Date: Jul 2007
Are any of the mounting tabs broken on the dash pad?
Is the pad curling anywhere?
![]() Join Date: Mar 2007
Will take the osprey, do you take paypal?
![]() Join Date: Nov 2008
I might be crazy, but doesn't the cam cover emblem indicate that motor is a '90? How many miles are on it?
#7 | |
The emblem is just sittin on there Mileage was told to me to be in the 30,000K range
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
![]() Join Date: Feb 2009
Johnny P,
I'll take those exhaust hangers. PM inbound. Rich
PM sent
#10 |
![]() Done sold and delivered!
