Old 08-08-2009   #11
flyin ryan
flyin ryan's Avatar
Default Re: 368 sleeves and pistons??
Originally Posted by lbszr View Post
Can pump gas still be ran with the 12:1?
Anybody know what the highest CR and still be on pump gas? Just
curious.
LT-5 specifically or just any engine in general?
Old 08-09-2009   #12
lbszr
lbszr's Avatar
Was just curious on lt5, found out the hard way 383 with hypereruetic keith black pistons dont hold up up to 10.5cr in a boat on pump gas, it still lasted quite(years, roller cam went in, it lasted 5 hours) a while till it broke the top land off the piston and wasn't room in cyl for it at 6000.
Old 08-09-2009   #13
blackjack
kb pistons will do that once in a while,if the rings are set too tight
bj
blackjack is offline   Reply With Quote
Old 08-11-2009   #14
rkreigh
12-1 is pretty high for a "non lt5" engine
the new direct injection and efficient combustion chambers help
as does the variable cam timing
the lt5 of course benefits from an efficient clover leaf combustion chamber and a dished piston at high CR and is pretty detonation resistant even at high CR
Old 08-11-2009   #15
blackjack
you must also remember that you reach a point of diminishing return,with compression ratios;
you get more hp by going from 8 to 9:1 than you get
going from 11 to 12:1
bj
91/1735
98 c5
2002 z06 w/procharger
