Old 07-29-2009   #41
flyin ryan
flyin ryan's Avatar
Default Re: Rough Idle/Hesitation/Backfire
Originally Posted by Gary Yarbrough View Post
Don't get me wrong, I fully trust Jeff's opinion that the belt isn't causing the hesitation and I am very grateful for his and everyone else's advise! I was just asking if it is a problem in a more general sense. The loud clapping sound that seems to be coming from it when I floor it from idle doesn't seem like a good thing. But, I've got a lot to learn...
The learning never stop for all of us Gary. Your keeping your ears open & paying attention, that's all good . This noise your talking about from idle, is it when your in neutral/park, under load/power or both?
Old 07-31-2009   #42
Gary Yarbrough
Code 63! Today I took the car for a long drive (120 miles) and I got the dreaded SES light. When I got home, I pulled the codes and got code 63 (it flashed this code three times). I just changed the left oxygen sensor. Could this mean that I need to change the right one too? Could this be the source of my issues?
Hopefully, tomorrow I'll get time to do all of the other checks that Jeff suggested. I'm so swamped right now that it is hard to get anything done!
Gary Yarbrough is offline   Reply With Quote
Old 08-01-2009   #43
bldavis11
I would say you're up for the starboard oxygen sensor!
bldavis11 is offline   Reply With Quote
Old 08-02-2009   #44
GregCrowe
Start on this page and keep reading:
http://zr1netregistry.com/forum/show...t=1777&page=16
Those Accell coils are garbage. They made my car run like complete crap, backfire, etc.
GregCrowe is offline   Reply With Quote
Old 08-02-2009   #45
Gary Yarbrough
Crap! I changed the second 02 filter and it's no better (well...it actually seems to run stronger on the top end, but it could be my imagination since I haven't slept much this week). It is now "backfiring" again. The "backfire" is coming from the plenum area for sure. Hopefully, tomorrow I'll get time to ohm out everything. I've got to get some gaskets ordered, I've run out of spares... I sure hope that my Accell coils aren't the problem.
Old 08-03-2009   #46
flyin ryan
flyin ryan's Avatar
Cool Re: Rough Idle/Hesitation/Backfire
Got to say I feel for ya'...your having a tough go of it Gary. Just keeep telling yourself, 'It's something, It's something'...just have to pin-point it . Keep your chin up, bud
Old 08-03-2009   #47
flyin ryan
flyin ryan's Avatar
When is it backfiring 'Exactly' Gary? Off idle, light load, Trottle 'Tip-In', W.O.T. (Wide open throttle) under load (power) .
Old 08-03-2009   #48
Gary Yarbrough
The backfire only happens if I am at idle and I go to W.O.T. If I'm just parked and I go from idle to W.O.T. it only does it some times. If I'm coasting (say 7-8 mph) and go to W.O.T. it does it 80-90% of the time. So I'd say that it is worse under a load.
Old 08-03-2009   #49
ittlfly
Did you read this link as suggested by Greg? Especially pages 17 & 18? Your problem sounds very similiar.
ittlfly is offline   Reply With Quote
Old 08-03-2009   #50
Gary Yarbrough
I did read the link as suggest by Greg.
I checked the resistance of the coils I removed and here is what I got:
0.6/5.7K
0.6/5.69K
0.7/5.88K
0.6/5.62K
So, I don't think coils were my problem to begin with. However, I could be wrong and would be glad to hear it if I'm thinking about this the wrong way.
Maybe today I'll get time to pull the plenum back off and ohm out the plug wires and new coils.
I have noticed something else that might be relevant. When I'm sitting and I go from idle to W.O.T., I can hear a bit of a sucking noise for maybe 1-2 seconds. Could I have a vacuum leak or is a sucking noise from the throttle body normal?
