Old 07-30-2009   #21
Default Re: ZR-1 Ten Commandments
Thou shall shall answer in earnest that the cost of all LT-5 repair parts and ZR-1 speed modifcations are fixed at a price point of "only $100" to all spousal support units.
Old 07-30-2009   #22
tccrab
tccrab's Avatar
Thou shalt not attempt to speed shift into second gear unless the clutch pedal is depressed completely to the floor.
Thou shalt not release copious clouds of tire smoke inside ones own neighborhood, especially if the proximity of said demonstration is such that your significant other can hear the siren song of a high revving LT5 engine and the squeal of rubber being scrubbed onto the pavement.
TomC
"Crabs"
Old 07-30-2009   #23
Originally Posted by ZR1@LAST View Post
Will this cause damage to the engine or take away the thrill of driving the beast?
Thanks,
Jeff
both....sorta. driving with the power key off, ya know i keep hearing it has an off position never seen it myself, won't let you kep the secondaries healthy
Old 07-30-2009   #24
Stay in off position long enough then after 12 midnight and "poof!" you will find LT1 under the hood - not that there is anything wrong with it!
Old 08-01-2009   #25
cvette
Thou shall purchase parts 2 by 2 when the opportunity presents itself
Thou shall not let butchers build engines
Thou shall not let Moudy work on cars lest screws will disapear
Charlie
cvette is offline   Reply With Quote
Old 08-02-2009   #26
ZR1@LAST
Thumbs up Re: ZR-1 Ten Commandments
I totally understand. It's like driving my Grand National with no boost
When I bought the ZR1 recently, I did not have the key in the full power mode. I have since made up for that 11 hour drive in the rain and now having too much fun...
Thanks,
Jeff
90 ZR1
ZR1@LAST is offline   Reply With Quote
Old 08-02-2009   #27
Thow shalt P&P the top end (at least!) and thus UN-CAGE the BEAST as soon a possible!
p.
Old 08-02-2009   #28
GregCrowe
Thou shalt not spend a ton of money replacing injectors without ohming out the coils first :P
I keep seeing more threads with people continuing to recommend injector replacement and it turns out to be something to do with the coils.
GregCrowe is offline   Reply With Quote
Old 08-02-2009   #29
I understand your concern.
I have never tried it but there is a relatively inexpensive tool ($150+) where you can touch the plug boot with motor running that will tell you whether plug is firing or not.
http://www.sparkplugsensor.com/
Also, it is my understanding, one coil fires 2 cylinders. Therefore, if you determine 2 sets of plugs corresponding to one coil are both not firing obvious suspect would be coil.
Having said that, based on my experience (two out of 6,700+ production), coil seems to be less of a weaker link then injectors. I suspect introduction of ethanol seems to have contributed to this. Just my thoughts.
Old 08-02-2009   #30
Thou shall not ask a bunch of dumba$$ questions only to profess to know the answers they are givin by the people that actually know what there talking about.In the process,alienating oneself from the Brotherhood,buy a C5 instead.
