Old 07-24-2009   #11
Gary Yarbrough
Default Re: Rough Idle/Hesitation/Backfire
Well....I changed the coils today and the problem is still there. On the upside, I now have a very strong spark when I pull the plug wires. So, it's plugs tomorrow (if I get a chance). I have three questions:
What's the proper torque for the plugs when i put them in?
How do I get out the rear plug on the passengers side?
Any other suggestions for what I should be looking for?
Thanks for any help I can get!
Gary Yarbrough is offline   Reply With Quote
Old 07-25-2009   #12
DVM the TPS sensor. Also, while the car is idling jiggle each of the three wires on the TPS.
? Anything?
Old 07-25-2009   #13
Gary Yarbrough
Maybe the TPS is my problem. I saw three wires: blue, white and black.
Between the back and the other two, I get ~4.5 and 4.0 volts. Does that sound possible and what's next?
Old 07-25-2009   #14
Kb7tif
Did you use d545 coils?
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Old 07-25-2009   #15
Gary Yarbrough
I used Accel coils.
Old 07-25-2009   #16
ZR1Vette
ZR1Vette's Avatar
Rear plug... bit of a challenge but basically you need a plug socket, short (1 1/2") extension, universal and then a longer (4") extension
Have you checked your ALDL/DIC for any fault codes?
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 07-25-2009   #17
Just thought you might look this over about #8 plug r&r...
http://www.zr1netregistry.com/ZR1_techtips.htm
This is the ticket. 20 N-m ( 15 lb-ft ) on the 90 plugs w/the flat seats & flat washer.
On the TPS, Black is sensor ground, Dark Blue is the signal to the ECM, and Grey is 5v reference signal from the ECM. ckt #'s 452, 417 & 416 respectively. Therefore you should read the TPS signal from the TPS to the ECM at the Dark Blue wire. A back probe on the Dark Blue (417) should yield a reading between .46v & .62v. If I understand the book correctly.
Old 07-25-2009   #18
Gary,
With key ON, the TPS signal (between black wire and blue)
should be around .54v. Once you have it set up, read the TPS signal voltage as you open and close throttle with motor off but key ON. See if the voltage change is smooth or changes in a "choppy" manner. Does the reading change abruptly? Also, make certain the TPS switch assembly is securely attached and not loose. Move switch wires around and make certain voltage readings aren't changing.
Old 07-25-2009   #19
Gary Yarbrough
I checked the TPS voltage. I get 0.37v. With smooth pushing of the accelerator, the voltages fairly smoothly (maybe 0.5 or so v increments). Flooring it, it goes from 0.37v directly to ~2.5-3.5v. Time for a new TPS?
Old 07-25-2009   #20
Gary, I have a 90 and I know for sure that my TPS is adjustable...to what degree I don't know, but the screws that hold it in place are in slotted holes, therefore I conclude it's adjustable.
You may want to look closely at those screws as you maybe able to make an adjustment. If you say that the needle on the VOM moves thru it's sweep at a smooth progression then maybe an adjustment is in order.
Just a fwiw, try it, in the end you can always go spend the money if the adjustment don't work.
