Old 07-22-2009   #11
Scrrem
Scrrem's Avatar
Default Re: Baer 6-piston calipers at reasonable prices
Originally Posted by Aurora40 View Post
http://www.baer.com/announcements/20080808/index.php
Anyone else see this? $1,100 for a 6-piston setup that sounds like it will fit under most wheels. And it uses C5/6 pads. Any opinions on this as an upgrade? I'd assume it is not as heavy duty as a larger caliper, but if it's on par with something like the older Brembo 4-pistons, that's not bad at all for the price.
It doesn't say anything about the rotors used though.
Bob,
I did you end up going with this Baer setup? If so, how are they?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-22-2009   #12
tf95ZR1
tf95ZR1's Avatar
I bought these and they look great but
they rubbed against my after-market 17" rims.
I switched back to GS calipers and the Baers
sit in my garage until.............
Old 07-22-2009   #13
Aurora40
Aurora40's Avatar
I did buy them. They clear my AFS 5-spokes, though by a thin margin. You can't fit a finger between the caliper and the spoke.
They are a nice upgrade at this point. I had lots of initial hassle though. But by now they should include a properly sized banjo bolt. Also, buy a decent brake pad to use. The included ceramic pad is terrible.
Rich, if you want to check them out in person, let me know.
Old 07-22-2009   #14
Scrrem
Scrrem's Avatar
I may take you up on that. I am not really happy with the stock brakes and was browsing the site when I ran across your post. Maybe we can hook up some weekend. Not going to the Corvette Cruise in Manasas on Aug 8th are you?
Rich
Ron Davis Radiator
Old 07-22-2009   #15
Aurora40
Aurora40's Avatar
I didn't know about it. I wasn't planning on going, I'm not really into the car show scene. I'll see though. I could stop by Chik-Fil-A in Dulles some Friday night if you ever get out that way. There may be better roads to take a quick spin on there without so much traffic than in Manassas.
Old 07-23-2009   #16
Aurora40
Aurora40's Avatar
What kind of wheels do you have?
Old 07-24-2009   #17
tf95ZR1
tf95ZR1's Avatar
17" OZ "Fittipaldi"
