Old 07-10-2009   #11
Default Re: McLeod Flywheels-aluminum
Just got the Mcleod Flywheel.....16.5lbs
Bought the Beck/Arnley kit off Rock auto for $111.00
**Pressure plate is Valeo
LT-1 Clutch disk on its way $64 off ebay(Thanks Dominic)
Anyone interested in the LT-5 Clutch disk that came with the kit let me know....again its a Beck/Arnley kit...pressure plate was Valeo....disk however says Made in China. Asking $40
Old 07-11-2009   #12
Yeah I will take it
Old 07-11-2009   #13
$30 for you jeffy
Old 07-11-2009   #14
Cool
Old 07-13-2009   #15
Anyone know if the Mcleod flywheel requires different bolts?
Old 07-13-2009   #16
As I understand it I can use GM LT1 Fbody Flywheel bolts?
Old 07-13-2009   #17
jonszr1
jonszr1's Avatar
jerry of jerrys gaskets has the lowdown on the bolts
Old 07-17-2009   #18
Can you use a 7/16 1.5 with a thicker hardened washer? Finding bolts is F@#king pain in the AZZ
Old 07-18-2009   #19
Distance between the washer and crank is .521" torqued to 25ftlbs.....flywheel thickness is .537.
There is a decent sized tip on the bolt, grind it down and use them or is this too close?
Old 07-18-2009   #20
found 1.25
