Old 06-24-2009   #1
QB93Z
QB93Z's Avatar
Default Electrical Connector Repair
On my 1990 ZR-1, the oil pressure gauge indicated pegged-high. I looked at the oil pressure sensor and found that the electrical connector was secured with tape. I pushed it in and the oil pressure gauge indicates properly. When I looked at the connector, I found that the clip was broken off. This is a problem that happens a lot on our cars.
I searched for a way to repair or replace the connector. I found a good source to solve this problem:
http://www.repairconnector.com/
Many of the WeatherPack connectors on the LT5 are available on their website, and they sell the tools to replace the connectors.
The connector I bought came with wire pigtails installed and butt splices. The repair can be done by cutting off the old connector and then crimp-splicing the new connector to the wire harness.
But there is a better way.
Here is the oil pressure sensor after I repalced the connector:
Here is how it works:
The tool is used to remove the wires from the connector by pushing it into the face of the connector (This picture is on my bench, the same procedure is used on the engine):
Then the wire on the engine harness can be pushed into the back of the new connector, and the black wire retainer is replaced to secure the wires.
If it isn't fun, you aren't doing it right!
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 06-24-2009   #2
jonszr1
jonszr1's Avatar
Default Re: Electrical Connector Repair
wow thanx for the info .i have a lot that need replacing
Old 06-24-2009   #3
Jagdpanzer
Jagdpanzer's Avatar
Great information Jim, thanks for sharing
Old 06-25-2009   #4
Yea Jim, thanks for sharing this info.....
Old 06-25-2009   #5
billybaloneey
billybaloneey's Avatar
Your picture, (the first one), on the connector installed on the sensor, it shows a light brown wire coming out of the back of the connector, your how-to picture, (the second one), shows a black wire. Did you have to replace the whole length of wire in the harness to the sensor? I don't have mine memorized, so I don't know if there are one or two wires...a black one and a light brown one), on that sensor/connector.
A lot of people must have just recently visited & bought the connector pin push tool set...the link to the vendors web site said they only had 1 set left in stock.
Thanks for the How-To tip.
Clint aka billybaloneey
'94 - C4 ZR-1 #445 - Black/Black
'05 - C6 silver/black 6sp
'85 - C4 white/graphite (almost done) automatic
'78 - C3 silver/black (a work in progress) automatic
billybaloneey is offline   Reply With Quote
Old 06-25-2009   #6
QB93Z
QB93Z's Avatar
I did the repair and then decided to post the info. So, I had to recreate some of the scenes. (Some of the names have been changed to protect the innocent)
Bottom line, The light brown wire from the harness to the oil pressure sensor is the original wire. The black wires shown in the bench picture came mounted in the new connector. I removed the black wires from the new connector and I removed the light brown wire from the broken connector. Then I inserted the light brown original wire into the new connector.
Note: this is a three wire connector and the system only uses one wire, so there a two hole-filler plugs to keep moisture out of the connection. You can see the orange tip of one of the hole fillers in the LT5 picture.
Old 06-25-2009   #7
Pete
Pete's Avatar
Good job Jim.
For the Chicago boys here's a place in our back yard they will take care of you while you wait.
https://www.casperselectronics.com/s...contact_us.php
They'e in Mundelein,IL same town as Flatout Gaskets pick up some gaskets while there.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-25-2009   #8
billybaloneey
Ah...mystery solved.
