Old 06-15-2009   #31
Default Re: 6/14 Antioch IL Car Show & Dyno - FBI
You said rear wheel torque. That's 440+ at the crank. A 70lbft increase??
Then everyones readings on the Performance page must be wrong
Looking at the stockers the rwtq is about 320-330 so its only a 40 ftlb gain at the wheel, I think you are assuming a nearly 20% oss through the drive train.
Old 06-15-2009   #32
My car dyno'd 385rwhp and 350rwtq. That's one reason why I'm skeptical.
And 30lbft less than Pete is another.
Hans is running the LT-4 resonator, which isn't bad according to Marc H.
Also an Xpipe IIRC.
no he isn't. I thought Hans said the LT-4 Resonator would not fit with the X-pipe so he is running a Magnaflow piece
Old 06-15-2009   #33
Ccmano
Had a great time yesterday, great to see the everyone. As for the dyno numbers I'm sure the system I am using is causing the lower hp reading. When Twisted Pipes redid the exhaust late last year we went as follows:
SW headers - magnaflow HF cats - X-pipe -Magnaflow Resonator - Corsa Mufflers.
As far as I'm concerned the car now sounds perfect to me. No resonance, I can carry on a conversation under normal driving conditions and screams nicely at WOT.
The next test will be at the track.
Here's a few pictures from yesterday..
H
Old 06-15-2009   #34
Hans,
I wouldn't come to any conclusion until you have had a chance to review your results and optimize the tuning.
Old 06-15-2009   #35
jonszr1
jonszr1's Avatar
if someone has a fax number that they can give me i could fax my dyno sheet from when corey ported and tuned my blk car . 409.9 rwhp and 373.3 tq. white callawaymade 389.33rwhp 361.72 tq
Old 06-15-2009   #36
Ccmano
Hans,
Don't get me wrong Dom, I still plan to do some further tuning. For that matter I would even switch exhausts again if one surfaced that had little to no resonance, is reltively quiet at cruise and flowed better than what I have.
I've been toying with the idaea of using a stock LT4 system behind my cats (according Haibeck the resonator has virtually no restriction) and replaceing the stock mufflers with 3" magnaflows. The LT4 stock system has a crossover built in, unlike the later LT1's and ZR-1's.
H
Old 06-15-2009   #37
jonszr1
jonszr1's Avatar
there is am article by hib that shares what he did with an lt4 and flowmaster system that made 28 hp over stk .something to consider .
Old 06-15-2009   #38
Pete
Pete's Avatar
On the Dyno #'s
I would double check them a different dyno,that's what i do 2 different dynos 2-3 different tracks.
Now that i think about it 370 370 seem a bit wierd.
What were Don's #'s?
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-15-2009   #39
Don was 360hp and 355tq if I recall
Pete go to the perforamnce page...most cars with that level of mods are similiar....cammed cars have a wider range.
Old 06-15-2009   #40
Pete
Pete's Avatar
I see that and noticed the early Z's had closer #'s then the later Z's.
I would still double check the #'s.
I think Hans car will make 390-400 without all the exhaust restrictions.
I would bet HP would go up but TQ would remain.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
